SDR# TETRA Demodulator Trunk Tracking Demonstration
jlmarc33
France
Thank you for your help and your tests.
I have installed last SDR# and TTT on another PC (Laptop with W10 Home v1909 - french),... and I can't reproduce the problem seen on W10 Pro v2004.
I will continue to investigate about my W10Pro security parameters.
Motik
France
Hi,
I'm getting an error which I can't find how to correct, although I'm sure I already corrected it in the past on another computer :rolleyes:
When launching TTT it complains about syntax errors where, instead of the expected values "true" and "false", it finds the equivalent in my local language (French) :
11/11/2020 11:26:19
Unknown ERROR[RAW]:
Last DATA: Result:Error,Type:Syntax error,Message:{\command\: \set\, \method\: \netinfowindowopen\, \value\: vrai}
Syntax error in \method\: \netinfowindowopen\ invalid \value\: vrai}
Call active: Faux
tmrSaveTimed: Vrai
I know the error comes from inside TTT because it also saves GSSI info with the same translated values, although the TETRA plugin in SDR# correctly uses English values.
from TETRA_GSSI:
3001922;208;82;;0;Vrai
3001926;208;82;;0;Vrai
3003922;208;82;;0;Vrai
3003923;208;82;;0;Vrai
from tetraSettings.xml:
<AutoPlay>false</AutoPlay>
<IgnoreEncodedData>false</IgnoreEncodedData>
<IgnoreEncodedSpeech>false</IgnoreEncodedSpeech>
<TttModeEnabled>true</TttModeEnabled>
<TttUdpPort>3383</TttUdpPort>
<IsCc>true</IsCc>
As said, I have another computer where this problem doesn't appear, and on which I remember getting the same errors and finding how to correct them a year or so ago...
Anybody can point me to the right direction?
thewraith2008
Hi,
11/11/2020 11:26:19
Unknown ERROR[RAW]:
Call active: Faux
tmrSaveTimed: Vrai
from TETRA_GSSI:
<IsCc>true</IsCc>
I don't know why this works OK for some people/PCs and not other people/PCs.
I did a test (mentioned here) and could not repeat error.
This makes it hard to work out problem.
While TTT is reporting the error, it looks like the plug-in has the problem as noted by the response: "Result:Error" for "netinfowindowopen".
Plug-in could be expecting "True" instead of "vrai", but why does it work on other PCs in same region?
Latest version (v1.7.1.0) can be found here: Release post
Motik
France
Thank you thewraith2008 for your answer (and for the amazing work on TTT!) I had forgotten about that other French person who got the same error although it was only a couple weeks ago and I had myself answered that I didn't have the problem (on my other machine, obviously) :oops:
FWIW both my machines are running the same version of Windows 10 Insider (20H2 19042.610). I'll try to find what differences there are.
thewraith2008
@Motik : I have done another test with the following system settings changed:
Code:
Languages           > France
Preferred languages > France
Region              > My Default Region
Region format       > English
Language for non-Unicode programs > English
Languages           > France
Preferred languages > English
Languages           > France
Region              > France
Region format       > French (France)
Languages           > France
Region              > France
Languages           > France
Region              > France
Language for non-Unicode programs > French (France)
Languages           > France
Region              > France
TTT is starting as expected with the plug-in.
When TETRA_gssi.txt is created/saved, it uses "True" not "Vrai"
It is assumed that that commands sent to the plug-in are also sending "True" not "Vrai".
It seems likely that the plug-in is having a problem with the boolean type and not translating "Vrai" as "True".
I could probably make this a fixed string, but I would prefer to find why this is occurring only in some cases.
Do other French users with a working TTT out there see "Vrai" in the TETRA_gssi.txt file or is it using "True"?
jlmarc33
France
@thewraith2008 and @Motik.
Hi,
With my fully working TTT on laptop (W10 Home, french, now in 20H2 release), all TETRA_GSSI.txt lines are generated with "True" strings.
On my desktop, with netinfowindowopen error (W10 Pro, french, 20H2), TETRA_GSSI.txt lines are generated with "Vrai" strings.
thewraith2008
Hi,
Well, so far the only obvious difference is Window 10 Home and Pro.
Do you see the same settings (in Languages and Region) between the Desktop and Laptop in Windows 10?
Code:
Languages
Preferred languages
Region
Region format
Another possible guess, is that the installed .NET runtime libraries maybe of different languages between desktop and laptop
Not sure how you would check this.
I would have also expected to see other people with languages other than English mention this problem by now.
Strange indeed.
SignalPatcher
I got interested in the signal below. It has got width 50 kHz. It is on 390,9750 frequency and sounds like TETRA. I managed to read that it might be TEDS, but there is no available decoder which reads that. I'm sending links about TEDS below and a recording. Could anybody have a closer look on that?
TETRA Release 2 - TCCA
https://www.etherstack.com/us/pdf/TETRA-TEDS.pdf
About TEDS (TETRA2) Modulation Analysis
TETRA DIB-R5 | TETRA Systems
https://core.ac.uk/download/pdf/80702135.pdf
https://www.bakom.admin.ch/dam/bakom/en/dokumente/faktenblatt_tetra.pdf
jlmarc33
France
Code:
Languages
Preferred languages
Region
Region format
Strange indeed.
Here are the results
1) Language and Région parameters check
On desktop PC: Windows 10 Pro - 20H02 (19042.630)
Windows feature experience pack: 120.2212.31.0
Languages > French (France)
Preferred languages > French (France)
Region > France
On laptop PC: Windows 10 Home - 20H02 (19042.630)
Region > France
... so, same Windows configuration for Language and Région parameters.
2) .NET framework version check
Need to know the .NET version on Windows 10? Here's how in three ways.
I used W10 PowerShell console to check the installed .NET versions with the following command:
Get-ChildItem 'HKLM:\SOFTWARE\Microsoft\NET Framework Setup\NDP' -Recurse | Get-ItemProperty -Name version -EA 0 | Where { $_.PSChildName -Match '^(?!S)\p{L}'} | Select PSChildName, version
In W10 Pro, I found different versions of .NET framework
In W10 Home, I found only last 4.8 .NET framework (the last 3 lines in PS console).
thewraith2008
@jlmarc33
Not sure if it really matters, but can you check the language of the v4.x .NET runtime on both desktop and laptop?
I'm guessing that these were already installed with Windows 10 Home/Pro, but it can't hurt to check anyway.
A possible way of determining this is to go to: "C:\Windows\Microsoft.NET\Framework\v4.0.30319" and look at the properties (right click file) for "Accessibility.dll". Look at the "Details" tab and find "Language" property: e.g. English (United States)
thewraith2008
This would require something to be made from the ground up.
- Demodulator for 4/14/32/QAM
- Decoder for the layers above the physical layer.
- MELPe Voice Codec or AMR
- Months/Years of time
This would require at least the air interface/voice codec standards documentation.
I would not be motivated to do something like this if it did not exist locally (which it does not).
Most providers here have/are shutting down TETRA and seem to be opting for the cheaper lower quality DMR.
Sinager
Hi,
I run successfully TTT on several other PCs, however there's one where the Tetra Plugin crashes SDR# with this .Net error:
************** Testo dell'eccezione **************
System.NullReferenceException: Riferimento a un oggetto non impostato su un'istanza di oggetto.
in SDRSharp.Tetra.TetraPanel.AfcTimer_Tick(Object sender, EventArgs e)
in System.Windows.Forms.Timer.OnTick(EventArgs e)
in System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
in System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Unfortunately Win10 doesn't allow reinstalling .Net these days.
Any hints? I'd rather not wipe and reinstall the full system.
SDR# version doesn't seem to matter.
Standard (non TTT custom) Tetra plugin gives the same error.
Full log attached.
Sinager
  • 1772.txt
jlmarc33
France
@jlmarc33
@thewraith2008
I checked all Acessibility.dll for desktop and laptop PC in C:\Windows\Microsoft.NET\Framework\v4.0.30319, and also in \Framework64 directory.
They all own the same language property : English (United States).
... No new tracking idea.
thewraith2008
@Motik @jlmarc33 and maybe @Sinager
I think I may have an answer to your problem.
In the newer SDR# (around v1733+) a feature was added for the lazy loading of plug-ins.
This will stop the plug-in from running the UI if the side panel for plug-in is minimized.
This results in an internal error when TTT tries to set 'netinfowindowopen' (because UI is not there) and the plug-in returns the error response to TTT which just keeps retrying it and will not proceed until it gets a OK response from the plug-in.
So if the plug-in side panel is minimized when you start TTT, then the following error is seen:
Code:
14/11/2020 9:35:46 AM
Unknown ERROR[RAW]:
Last DATA: Result:Error,Type:Syntax error,Message:{\command\: \set\, \method\: \netinfowindowopen\, \value\: true}
Syntax error in \method\: \netinfowindowopen\ invalid \value\: true}
Call active: False
tmrSaveTimed: True
So make sure it's not minimized and it should be OK.
Let me know if this works for you.
Release post
Motik
France
Code:
Unknown ERROR[RAW]:
Call active: False
tmrSaveTimed: True
Release post
Thank you @thewraith2008 for investigating this. Unfortunately, in my case, the TETRA demodulator side panel has always been open.
