SDR# TETRA Demodulator Trunk Tracking Demonstration
merlin
DN32su
I need the line that is circled. As many as you can, and from different people so I can validate my method.
The carrier is "Current:" 2604 with the frequency of 865.1125 MHz.
What I gather is you need two different sets to calculate a Fb from then see if the formula works for others.
thewraith2008
I don't have any TETRA in my area to monitor.
I do stuff to it if I can, but I mess around with many different things and my focus changes (squirrel)
Latest version (v1.8.6.0) can be found here: MEGA - Download
Release post here
LA6FRA
Stavanger. Norway
Have a look at this thread (TetraNetMonitor)
This creates multiple VFOs to monitor the carriers.
This works with calls in a first in first played basis. (i.e. does not play calls from different VFO at same time)
Release post here
Thank you for your quick answer.
I have been using TNM for a while and it works really well but not in the way I want to. I guess I have to use 1 dongle per TG if I want to acheve the same as with DSD+
thewraith2008
Can you not do a similar thing to the DMR setup you mentioned?
Have SDR# with 3 AUXVFO tuned to each carrier (or same one) with the the outputs of each AUXVFO going to different VB cables.
Then run 3 instances of SDR# with the TETRA plug-in using soundcard as source with VB cables as input.
Release post here
thewraith2008
Did you try and set the AUXVFO to WFM (in image it's set to RAW)
Make sure WFM and Bandwidth are set in SDR# as when you click 'Set' in AUXVFO it does not always use what you set in the AUXVFO side panel.
AUXVFO has some bugs and inheritance issues that make it annoying to use sometimes.
Release post here
FERRAINAELENA
ITALIA
hello, my question and this I live in an area with a lot of dark traffic all encrypted air 1.
Is there a possibility that there is free-to-air transmission inside a telephone cell? or are my attempts in vain? Thanks for the attention.
LA6FRA
Stavanger. Norway
If the TETRA network/site belongs to a goverment agency it is probably encrypted with TEA 2, if they have paid for it. If not the transmision is open.
FERRAINAELENA
ITALIA
but you think it is still possible to listen to something ...
how can i notice if there is something in the clear?
can you help me identify the transmission without encryption.
LA6FRA
Stavanger. Norway
We have a lot of tetra networks in Spain. In Cataluña, the regional tetra network RESCAT, is encripted for all transmisions for National Police, but Local Police, like Bracelona (Guardia Urbana) and other emergengy services are unencrypted
oe5kbo
Wels Austira
I normally use 32 bits and when I copied TETRA set-up to 64bit laptop I forgot to try 64 bit Net Remote plug-in.
As it's only a TCP interface I'm not going to worry about it. 32 bit version works just fine.
gustavobm, when you hit post 4 or 5 you should try and PM me and I'll send you details on where you can send me those logs.
hallo can you help me for a download link for the tetra trunk tracker ore can you sent me a file. Thanks for helping.
jomeg0
Hi all,
First of all I love this software. Many many thanks to thewraith2008 for this great app.
I hope to see more features in the future ;-)
One change I am having trouble understanding is what thewraith2008 mention here:
Changed: When TTT mode is enabled, the 'Auto' checkbox is replace by label "TTT Enabled"
- NOTE: The timeslots are under control of TTT when in TTT enable mode.
Before this change, I could lock out every communication except the ones I want to listen to.
In the beginning when I started using this plugin my lockout was interrupted by some private calls.
The solution for me was to put the CC part of SDRSharp constantly on timeslot 1 and
the VC part of the SDRSharp to Auto.
But now with this change I'm having problems trying to solve this.
When I use TTT Enable on both SDRSharps, I can hear the private calls I'm not
interested in (This communication needs to be lockout)
When I try to solve this by disabling TTT Enable on the CC part of the SDRSharp I don't receive any voice...
Any suggestions on how to deal with this after this change?
Many thanks
Jomeg0
hamradionl
Jomeg0
What i did. using the older version for trunk before the change and run a second newer version (doing nothing only for the SDS and the data futures.
About DATA on the network i spotted some messages show long HEX. Not often but sometime.
