SDR# TETRA Demodulator Trunk Tracking Demonstration
thewraith2008
Changed: When TTT mode is enabled, the 'Auto' checkbox is replace by label "TTT Enabled"
- NOTE: The timeslots are under control of TTT when in TTT enable mode.
Before this change, I could lock out every communication except the ones I want to listen to.
In the beginning when I started using this plugin my lockout was interrupted by some private calls.
The solution for me was to put the CC part of SDRSharp constantly on timeslot 1 and
the VC part of the SDRSharp to Auto.
But now with this change I'm having problems trying to solve this.
The quote means exactly what it states.
If you go changing timeslots when TTT expects the timeslots to be set to where it sets them. It undermines TTT control of a call.
The plug-in has two ways of been used, with TTT and without TTT.
When used with TTT, I've made the change to enforce timeslot control.
If you want to keep changing timeslots yourself, then don't use TTT as it not really doing anything anyway when used this way.
When I use TTT Enable on both SDRSharps, I can hear the private calls I'm not
interested in (This communication needs to be lockout)
Then why not just lockout all private calls like you would any other TG?
Set the GSSI: 0 to be locked out or just use the lowest priority (for GSSI: 0) and use a higher priority for your TG of interest so it will be switched to when seen.
Latest version (v1.8.6.0) can be found here: MEGA - Download
Release post here
hamradionl
Sorry to push in i know anyoing, we talk this matter in private conversation some years ago. there still are older systems not be Hytera branche, use other way configurated, that not work this way. So when using the auto mode/manual set to timeslot in the older version, used on the larged airport network in the world, you still able to fallow the other conversations on that particular slot and other slots and while also using the trunk. But we keep running in circles about this matter.
I be happy to read other users found out about the auto/manual function be very handy on a particular network configuration
About DATA:
D-OTAR shown or decoded
jomeg0
What i did. using the older version for trunk before the change and run a second newer version (doing nothing only for the SDS and the data futures.
About DATA on the network i spotted some messages show long HEX. Not often but sometime.
Hi thanks for your reply. I don't know if I get this. Do you mean I will have to run one SDRSharp using an older version of the plugin and another with a newer version? If so I will give it a try, but it would be nicer if the newer plugin offers the possibility to keep the selection of timeslot 1 as static on the CC side of the configuration. But thanks anyway for your help.
jomeg0
Release post here
Hi, oke thanks for this explanation, that was the part I didn't understand. So I can disable TTT mode on both side of the SDRSharp and control this manually again!!! I will try this out.
CQ1830
Please guide me. Why when I switch to tetra mode in sdr the speaker voice be muted.
Ubbe
Stockholm, Sweden
I think CQ are pointing out that TTT are automatically muting the speaker when it starts and he is worried that he will not hear any calls if it is muted. Perhaps it's the setting "Listen Only Clear Speech" in SDR# that have been selected and CQ has encrypted calls in his system.
/Ubbe
HamZeroAT
it would be very nice to add a call recorder. everytime when someone speaks automatically it will be recorded and saved! :D
oe5kbo
Wels Austira
Hallo Friends can anyone help me by installation of the TTT i have windows 10 or linux with RTL SDR
I have it now on the stick unzipped but i dont know how to install it if i open tetra trunk tracker exe in windows 10 it comes the not a waterfall
and not this window with the waterfall ????????? How can i install this ????? Thanks for helping oe5kbo karl 1637492095164.png
oe5kbo
Wels Austira
I have same issue. And I think that it has to do with new SDRSharp Software that sits on top.
But I have solve this with check On Top in Network Info window. I am not sure this has been that way for as long
as the SDRSharp has introduced Display parameters.
The best part of the new TTT is that it can now show a lot of encrypted trafic. And a lot of more information on
MS Registrations window.
Hi i posted i need help for installing the TTT Software. You use it already and give me a tip how to install it.
Can i have conversation with you, i need your help tnx 73 de karl oe5kbo
thewraith2008
@oe5kbo
In your first post, you are trying to pass audio out (of a TETRA signal) via AUXVFO through a virtual cable to a second SDR# with the source as "IQ from Sound Card". This audio out is not IQ data, this will not work this way.
The documentation explains how TTT and the TETRA Demodulator should be setup and used.
A recommendation is not to use SDR# version between v1717-1820. (use v1716)
Another recommendation is not to use every plug-in released for SDR# in the SDR# TETRA setup.
In second post, the error is clearly stated. TTT is trying to use a port that is already in use.
Since no setup details are provided and based on 1st post I'll go and say you have not setup TTT and the TETRA Demodulator correctly.
Release post here
oe5kbo
Wels Austira
@oe5kbo
Release post here
HALLO THANKS FOR INFO DO YOU HAVE A GOOD DOWNLOAD FOR THE VERSION V1716. i google but didnt find a good download ????
karl
Marco192
Hi guys!
Maybe someone can help to explain the strange behavior I am seeing on a network that I monitor.
Every now and then there is some sort of an announcement or "all" call that goes out to many stations and groups. The strange thing is that I am always seeing a different GSSI that this call is made on. The following announcement call comes in on the GSSI one number higher then the last call. Those are always 8 digit GSSIs that are not common in the rest of the network.
It is always coming from the same ISSI.
Thanks!
Ubbe
Stockholm, Sweden
Is that a voice announcement or text? What do they say or write? How often do they make those announcements? High GSSI numbers can be reserved for special use, like patches or phone calls. Are the GSSI's in the 14000000 range or higher?
/Ubbe
