Sounds are played via whatever the default system sound device is.
OK, thanks!
I was hoping that there could be a way to change it manually
Goodmorning all,
Question, one of the users on the network I monitor is using SDS Location data. To show that on a map I'm using LRRP from a paid DSD+ version. It works great the loactions are all plotted on the map. The only problem I have is that TTT (v1.8.6.0) constantly gives an error "Could not access DSDPlus.LRRP File retrying". TTT can access the file from time to time otherwise I would not see the locations on the map.
The problem is the annoying 'Windows Error ping' that Windows plays every time this happens.
Has somebody a solution for this minor problem (changing the Windows sound schema is a solution but not my favorite)
ET
Hi tomekjkp,Hello, as for TTT try to give it higher permissions for folder and file.
I propose to turn off this sound in the Sounds tab and there the default sound is missing. It works for me
Then it might improve even more with a faster access time so it doesn't hog the file too long. Create a RAM disk and have the LRRP file there. There are free programs to create small RAM disks in windows.... it was fairly large (50MB). I deleted the file and let it create a new file, it looks like the errors are less now.
Thats also a solution, but the file is already on a M2 SSD and I don't need the history. I don't care were the ISSI's where yesterday, I just want to know where they are nowThen it might improve even more with a faster access time so it doesn't hog the file too long. Create a RAM disk and have the LRRP file there. There are free programs to create small RAM disks in windows.
/Ubbe
If there is a lot of LRRP traffic, TTT is trying to always update the file and LRRP is trying to read the latest changes.Goodmorning all,
ET
Maybe as an option "Clear LRRP automatic for better performance" with an option to set the number of days you want to keep in history ?......
I think it's better to leave the clearing of the file to the user rather than letting TTT clear it.
Some may want this record of messages.
That would solve the issue for most people. Seeing the popup note about the failure to access the file are enough so that the user knows what's going on and can rectify it to his own liking.I have removed the beep for these LRRP tries, to be added for next release.
Can you record the tetra signals and after decode it ????The recording system in TTT is a simple one and requires somethings to be setup to work.
The documentation explains the two ways it can be setup.
TTT records using the default sound device for Windows.
Down side is, it will also record any system sounds.
If you use a virtual cable (as default device) you can avoid recording the system sounds, but you will need to enable the 'Listen to this device' so you can hear the audio decoded by the plug-in.
NOTE:
'Listen to this device' is what it's called in Windows 7, no idea if it's still called that in Win10/11.
It should be in the record options for the sound device you wish to use.
Latest version (v1.8.6.0) can be found here: MEGA - Download
Release post here
Yes you can. Use the plugin "IF Recorder" and set the WFM bandwidth to 250KHz and record that to an IQ file. When you select to play a IQ file in SDR# instead of RTL-SDR you select the file and TTT will use that. But it will only be able to follow calls that use a frequency within that 250KHz bandwidth, +/-5 channels of 25KHz each.Can you record the tetra signals and after decode it ????
