12th Public Release - TETRA Trunk Tracker and TETRA Demodulator plug-in - v1.0.15.5
With the recent changes to TETRA Trunk Tracker and the TETRA plug-in both may experience more frequent issues.
Bear with me through these issues and help if you can by supplying detailed reports of any problems you have.
(e.g. TTT version, TTT mode and selected options, Plug-in selected options and SDR# version and crash log if exists)
This package (version) of TETRA Trunk Tracker and TETRA Demodulator plug-in (with codec libtetradec.dll) are only meant to be used
with each other and with no other previous versions. To do so will most likely cause issues.
No changes to TETRA Demodulator plug-in in this release.
If SDR# is crashing when 'Demodulator' is enabled, it's because you have not set-up the plug-in correctly.
You MUST do this 1st. This is NOT TETRA Trunk Trackers fault.
You generally need to get these installed:
"Microsoft .NET Framework 4.6.2 (Offline Installer)"
"Microsoft .NET Framework 4.7.2 (Offline Installer)"
"Microsoft Visual C++ 2015 Redistributable" and install both 32/64 bit versions (if you use 64 bit OS)
This TETRA Trunk Tracker version changes/adds and fixes some items: (See "changelog.txt" for full list)
Code:
Summary of changes
v1.0.15.5
FIXED: TTT Dual mode
- SDR# VC was not returning to VC park after 'D_Release'.
CHANGED: Tweak to private calls detection of mode of operation (Simplex/Duplex) in some cases. Was not identified.
CHANGED: On call release, the timeslot is returned to timeslot #1 (MCCH) for SDR# plug-in (both if Dual mode)
- This is mainly to address the audio bleed through people have mentioned when TTT is idle
and a timeslot becomes active when it's still selected. This activity causes SDR# to un-mute and
audio can be heard on some set-ups even though volume is at lowest.
- For no other reason is this done.
ADDED: SDS unknown protocol IDs, DATA to text handling (Experimental)
ADDED: Status code labels (Experimental)
Has been tested on Windows 7 - Basic (64 bit)
Has been tested on Windows 7 - Professional SP1 (32 bit), English
Has been tested on Windows 10 - Professional (64 bit)
I have created it to suit my needs. And it currently works for me with the TETRA network I monitor.
I make no claim that it will work for other networks.
Please read the provided files for set-up and usage:
- TTT_set-up_manual.pdf
- TTT_Features_and_Usage.pdf
I have tried to be as thorough as possible with the documentation to explain usage and features.
I believe any questions can be answered by reading these files.
These files most likely are not complete and contain errors and are not laid out as good as they could be.
The TETRA plug-in is now been mainly tested with SDR# 1700 on Windows 7 Professional 32 bit with no issues seen.
The TETRA plug-in with SDR# 1700 on Windows 7-10 64 bit PCs is untested by me and is known.
It only works with the provided TETRA plug-in supplied in zip. (2019-April-15).
This version uses a custom compiled version of 'Net Remote' supplied in zip
It is only meant to be a temporary solution until something better comes along.
Please look at the "changelog.txt" for both plug-in and TTT as these maybe contain instructions/explanations for features that may not be covered in the PDF documentation.
Download
MD5 HASH 9464492a1841d4d67296525812d8a2d6
