thewraith2008
- Joined
- Nov 22, 2016
- Messages
- 1,886
14th Public Release - TETRA Trunk Tracker and TETRA Demodulator plug-in - v1.0.15.8
This package (version) of TETRA Trunk Tracker and TETRA Demodulator plug-in (with codec libtetradec.dll) are only meant to be used
with each other and with no other previous versions. To do so will most likely cause issues.
TETRA Demodulator plug-in has been updated by me. "Tweaked Edition (Unofficial) v1.0.15.8"
It's is required for some SDS features to work with TETRA Trunk Tracker v1.0.15.8. Please read text files in zip for plug-in.
This plug-in version changes/adds and fixes some items:
If SDR# is crashing when 'Demodulator' is enabled, it's because you have not set-up the plug-in correctly.
You MUST do this 1st. This is NOT TETRA Trunk Trackers fault.
You generally need to get these installed:
"Microsoft .NET Framework 4.6.2 (Offline Installer)"
"Microsoft .NET Framework 4.7.2 (Offline Installer)"
"Microsoft Visual C++ 2015 Redistributable" and install both 32/64 bit versions (if you use 64 bit OS)
This TETRA Trunk Tracker version changes/adds and fixes some items:
Has been tested on Windows 7 - Basic (64 bit)
Has been tested on Windows 7 - Professional SP1 (32 bit), English
Has been tested on Windows 10 - Professional (64 bit)
I have created it to suit my needs. And it currently works for me with the TETRA network I monitor.
I make no claim that it will work for other networks.
Please read the provided files for set-up and usage:
I have tried to be as thorough as possible with the documentation to explain usage and features.
I believe any questions can be answered by reading these files.
These files most likely are not complete and contain errors and are not laid out as good as they could be.
The TETRA plug-in is now been mainly tested with SDR# 1700 on Windows 7 Professional 32 bit with no issues seen.
The TETRA plug-in with SDR# 1700 on Windows 7-10 64 bit PCs is untested by me and is known.
It only works with the provided TETRA plug-in supplied in zip. (2019-May-10).
This version uses a custom compiled version of 'Net Remote' supplied in zip
It is only meant to be a temporary solution until something better comes along.
Please look at the "changelog.txt" for both plug-in and TTT as these maybe contain instructions/explanations for features that may not be covered in the PDF documentation.
Download
MD5 HASH 178aadb9dda7e8b6878cac8d6351cdfc
Code:
v1.0.15.8
FIXED: SDS PDUs that use text encodings('TextCodingScheme'): "ISO/IEC 8859-10 Latin 6" or "ISO/IEC 8859-14 Latin 8"
caused SDR# to crash.
- If above two text encodings are used, then "ISO/IEC 8859-1 Latin 1" will be used in there place.
- The PDUs that use 'TextCodingScheme' element will still show the requested encoding, but
will use the above stated text encoding.
Code:
v1.0.15.8 - Minor update
FIXED: SDS LIP 'Velocity' element handling error
- When non numeric value e.g.: "Velocity:Horizontal speed is not known"
- This will now be used when above is seen: "Velocity:0.0km/h"
CHANGED: If D_TX_Granted PDU seen with 'E2EE' then will report in call event log
- NOTE: If D_Setup is seen with 'E2EE', then call will not start.
- TTT_set-up_manual.pdf
- TTT_Features_and_Usage.pdf
Download
