thewraith2008
- Joined
- Nov 22, 2016
- Messages
- 1,896
- Reaction score
- 897
Do you not hear any private calls, Simple or Duplex?In the attached image are the changes from version 13. I have always had TTT configured as single mode. If I go back to version 1.11, I listen to private calls. If I install 13 or higher, I stop listening to them. Now I use TTT 1.20.2 which is the most stable version but I will try to install TTT 1.11 in another machine to see if I can provide more information. Thank you.
Something to check in the options.
- In TTT, check 'Options 2'. (Press 'O' twice)
- 'Play only when both ISSIs sen on private call'
- 'Disable SDR# CC switching for duplex calls not on MCCH'
- 'Disable ALT private call set-ups'
Maybe an seeing your logs and a IQ sample of a private call is needed.
Latest version (v1.0.20.2) can be found here: Release post
