The older scanners use IMBE, the X36's use AMBE.
Oh jeebus. So this is how this nonsense gets started...
Older scanners use IMBE because that's what Phase I P25 audio uses. You know -
the only digital voice protocol that those older scanners can decode.
Newer scanners use IMBE *and* AMBE+2, because they can handle P25 Phase I audio (IMBE) and P25 Phase II audio (AMBE+2).
They decode both protocols, so they use both codecs.
LSM systems are usually using AMBE with Phase II ones using AMBE II.
I'll just point out that you're suggesting that simulcast systems with Phase I talkgroups use AMBE for voice data, rather than IMBE, which would be a gross violation of the P25 standards.
And no P25 system, LSM or otherwise, uses "AMBE" or "AMBE II". They use IMBE for Phase I voice and AMBE+2 for Phase II voice.
Further, LSM, or lack of LSM, has
nothing to do with codecs. LSM, which is a hybrid AM/FM mode, is used for simulcast zones, while non-simulcast sites that are part of the same system might use FM (C4FM). A talkgroup isn't going to use one codec on the simulcast zones and a different codec on the non-simulcast sites, because a) that would be impossible, and b)
codecs have nothing to do with simulcast!
</rant>
But even with AMBE Vocoders, the X36's still do not even compare to say an APX on an P25 LSM system. Something scanner owners whine about.. I even used to til I realized, a scanner, no matter how good, is not an commercially designed radio specifically designed to handle multiple types of format to professional standards of 2 way comms. If an scanner was, then we would be paying over 2 grand for them. WEG!
Hm. $20 dongles handle LSM just fine. So much for needing expensive hardware.
