TrevDog
Hello all! I got a TK-250 and one TK-250(G) a while ago, but haven't done anything with them until recently. Anyway, I got the programming cable, a USB version- not USB-Serial adapter. I've tried using DosBox to run KPG23D and it works just fine except for the fact that the software won't recognize the radio when in PROG mode and attached with the aforementioned cable.
There are two options in the software as far as the input goes, COM1 and COM2. I've tried both, and neither work. I did some looking and found that none of the USB ports are COM's 1 or 2. More like 4-8, but I can't find what 1 and 2 are. My question is this: Is there a way to find out what COM1 and 2 are, or maybe a way to tie COM1 or 2 to one of the USB ports?
Can I even use KPG23D with DosBox, or do I need to setup Virtual Machine? I have an older Dell laptop with a floppy drive and no OS that I could install DOS on, but I'm thinking that then I would lose the USB functionality.
Thanks in advance for the replies!
