uniden 325p2/436hp vodecoder
Cameron County, Tx
hi, do any of you tech guys know this question can't seem to find it in research I'm upgrading my handheld 396 xt. i have all the software arc xt etc used 396xt many years so very familiar with programing but i heard the 436 has a better vodecoder but same speaker as 325 p2 so therefore sounds better. I'm in a non-simulcast area and use it mostly for home and work if there both the same in those regards more advantageous for me to keep with the 325p2 as the new learning curve on the 436 looks very complicated but would be worth it for a better sounding scanner if the vodecoder is better and not the same. thanks
ka3aaa
middletown, pa.
the only reason why the 325p2 may sound bad is the small size of the speaker in it, i don't think a 436 will sound much better, there fore i would keep the 325p2 and run an external speaker on it.
pb_lonny
VK7AAL
Tasmania
I used earphones with both of mine 99% of the time, I didn't notice much difference. The 436PT did have a better sound from the speaker.
hiegtx
Dallas, TX
As ka3aaa has noted, the main difference in sound between the 325P2 and 436HP is the speaker size. Plus, the 436HP has a larger case surrounding the speaker, which can also help. Based on what I've seen here in my area (DFW metro), the 436HP does marginally better than the 325P2 on Simulcast. But, as you've noted, Simulcast is not an issue at your current location, so that's not a factor for you at present. The better sound from an external speaker is probably your best, & least expensive, option. The small, 'pocket friendly', size of the 325P2 makes it an excellent grab and go scanner.
However, the learning curve on the 436HP does not have to be as challenging as you may think. Both scanners use the same basic style of programming. What your 325P2 calls a 'Group' is called a Department in the 436HP and other Uniden database scanners. The bigger difference is that, for your 325, you have a single programming file that you load & use. For the database scanners, you can have multiple Favorites lists, each of which is a programming file that you can tailor to more specific systems. You can use only a single Favorites list, or any combination of them, depending on what is happening in your area.
ka3aaa
middletown, pa.
the 436hp uses one large file known as a favorites list where everything is thrown into, verses the 325p2 that uses smaller system files that can be programmed one a time without effecting the scanners operations. the system files can be locked out simply by using system keys.
Cameron County, Tx
Thanks guys I decided to go with the uniden 325p2 because I already have the arc software and I have many many years with my 346 XT and 396xt programming them ,and I am very pleased I did, the audio is wonderful it's not as sturdy as I had hoped versus the 396xt but still good the one drawback I am sad about is I really love those colors I would do blue for EMS red for fire yellow for maintenance and sanitation etc but I really do appreciate your alls info it really helped thank you!
mancow
N.E. Kansas
The term is VOCODER as in Voice Encoder Decoder and they are the same.
