Uniden BCD436HP
juliuszallo
wappingers falls ny
So i need to put one DMR MOTO TURBO code in my scanner and cant figure it out.
Can anyone help please uniden said i can do moto turbo with the dmr upgrade wich i have so can someone who is good at this help me please.
W8RMH
Feed Provider Since 2012
What part are you having problems with? I was able to do it just by following the directions.
Applying the Upgrade
Download and install the latest version of Sentinel.
Use Sentinel to upgrade the scanner's firmware and database.
On the scanner, press MENU.
Select Settings --> Upgrades, then press E.
Scroll to DMR/MotoTRBO Upgrade, then press E.
Using the scroll knob to select each digit and the 4 and 6 keys to move left and right, enter each digit in the unlock key (including the hyphens between digit groups). Then, press E.
juliuszallo
wappingers falls ny
i got the update
i got the update done but i have one channel in need to put in and i got it in but i dont get the first half of the channel. its a weird noise then it picks up i have tryied everything and the channel just stops and make the noise every 5 mins it a police channel and i have it on my vertex evx-534 and it is clear as can be.
thank you for your reply
Ubbe
Stockholm, Sweden
If it only sounds data noise it isn't decoding. Try to enter the frequency manually, chan+frequency+chan.
If it still produces data noise it must be the DMR key that haven't been enabled properly?
/Ubbe
