SDS100/SDS200: Uniden SDS100 GPS Guide (2025)
sh7411usa
To reduce confusion from outdated forum posts and fragmented information, this guide consolidates the most up-to-date details on using GPS functionality with the Uniden SDS100 scanner. It is culled from numerous forum posts, notes, and personal research. While too numerous to list individually, a big Thank you to everyone who contributed to making this information available.
Using Location Services on the SDS100
  1. Avoid relying on Auto Locate.
    The Auto Locate feature scans active frequencies in your environment and attempts to determine your location by matching them against the internal database. Reports indicate that this process can take 7–10 minutes and is often inaccurate.
  2. Enter your ZIP code.
    The simplest method—without additional hardware—is to manually enter your ZIP code (North America only). The scanner will assume your location is the geographic center of that ZIP code. While this is generally sufficient, you must manually update the ZIP code when you change locations.
  3. Use a GPS receiver.
    Attaching a GPS receiver provides the most accurate and convenient solution, as the scanner will update its location automatically.
Choosing a GPS Receiver
Several options exist for adding GPS to the SDS100. These range from official Uniden products, to third-party receivers, to DIY external and internal modifications.
It is important to note that, as of 2025, many components—official and unofficial—are no longer available new.
Official Uniden Products
1. Uniden BC-SGPS Serial GPS Receiver
  • Includes: cigarette-lighter power cord, black power adapter unit, square GPS module (RJ14 connection at TTL power level), and multiple serial (RS232) cables terminating in USB Mini for use with scanners such as the SDS100.
  • Price: $99.99 (Uniden website).
  • Status: Officially available and currently supported.
  • Replaces the discontinued BC-GPSK.
2. Uniden CB-GPSK
  • Includes only the GPS receiver module and RJ14 cable.
  • For SDS100 use, it is not practical without the BC-SGPS power adapter and serial cables.
  • For SDS200, the RJ14 connection works directly without an adapter.
3. Uniden BC-GPSK Serial GPS Receiver (discontinued)
  • A round GPS “puck” with a PS/2 mini-DIN connector.
  • To connect to the SDS100, requires the additional Uniden BC-UTGC GPS USB Cable ($14.99, still available from Uniden).
  • Operates at 4800 bps.
Third-Party GPS Options
The discontinued Uniden BC-GPSK was functionally identical to:
  • Globsat BR-355S4 – Confirmed compatible with SDS100 (requires BC-UTGC cable). Discontinued.
  • Globsat BR-355N – Successor to the BR-355S4. Confirmed compatible, but as of 2025, no longer widely available, though not officially marked as end-of-life.
Summary:
  • It is not feasible in 2025 to purchase a new BC-GPSK, BR-355S4, or BR-355N.
  • If pursuing the “round puck + splitter cable” option, a used puck with a new BC-UTGC cable is your best option.
  • Otherwise, the Uniden BC-SGPS kit is the recommended solution, offering full support and compatibility with modern Uniden scanners.
Note:
Other Globsat puck models use USB connectors with FTDI chips instead of PS/2 mini-DIN. These may still be used in DIY modifications, but not with the standard BC-UTGC cable.
Unofficial Modifications
Two categories of modifications exist:
External Mods
  • Involve wiring a GPS puck directly to the scanner and a separate power source, or using a battery-powered GPS unit.
  • Some pucks lack PS/2 mini-DIN connectors, requiring cable modifications or custom-built splitters.
  • The SDS100 accepts GPS input through its Mini-USB port but does not provide power through USB.
  • Notably, GPS data must be routed to the ID pin of the Mini-USB connector rather than the standard data pins (as reported by user jonwienke).
  • Any GPS transmitting standard NMEA sentences at a supported baud rate should theoretically function if correctly wired.
Internal Mods
  • Involve installing a GPS chip inside the scanner’s housing, connected to both the power system and GPS input pin.
  • This voids the device warranty.
  • Most guides are now outdated, as the required components are generally unavailable. It does not seem that any services offering professional installation still exist in 2025.
Product Summary
  • Uniden BC-SGPS – Complete GPS kit for multiple Uniden scanners. Includes adapter unit, cables, and square GPS module. Uses 9600 bps baud rate. Retail ~$100. Available.
  • Uniden CB-GPSK – GPS module + RJ14 cable. Useful only as replacement parts, or for SDS200. Retail ~$50. Available.
  • Uniden BC-GPSK – Discontinued round GPS puck, uses baud rate of 4800 bps. Requires BC-UTGC cable.
  • Uniden BC-UTGC – Splitter cable for PS/2 mini-DIN GPS pucks. Still available (~$15).
  • Globsat BR-355S4 – Third-party puck, discontinued. Functionally equivalent to BC-GPSK.
  • Globsat BR-355N – Replacement for BR-355S4, previously ~$45. Not readily available in 2025.
Setting Up GPS
  1. Navigate to: Menu > Set Your Location > Set Up GPS.
  2. Select location format (affects Latitude and Longitude display fields):
    • DMS: DDD*MM’SS.ss
    • Degree: DDD.dddddd
  3. Configure serial port baud rate:
    • BC-GPSK / Globsat pucks – 4800 bps
    • BC-SGPS kit – 9600 bps
    • (Most scanners default is 4800 bps; must be corrected for BC-SGPS).
  4. Optional: Enable GPS indicators in the display:
    • GPS icon shows active connection to GPS (regardless of GPS fix).
    • Latitude/longitude fields will update as you travel.
    • If no GPS fix is obtained, the latitude field displays “NO GPS.”
Programming With GPS
  • Full Database Scanning – Location is automatically applied.
  • Favorites List Scanning– To enable location-based control:
    1. Enable Location Control for the favorites list is enabled.
    2. Ensure that location data is programmed for each site and department.
Note: Location-based scanning only functions if every relevant Department/Site includes location data.
tl;dr
As of 2025, the Uniden BC-SGPS kit remains the only officially supported and readily available GPS solution for the SDS100. Retailing at approximately $100, it offers a complete and reliable setup for accurate, self-updating location services.
ofd8001
Louisville, KY
This is some very good work!
I might suggest an addition: Do NOT cut off the 12V plug and direct wire to a power source. It will damage the device.
(Found that out the hard way).
Wonder if a sticky can be made of this.
ofd8001
Louisville, KY
I'll yield to the wisdom of others regarding placement of this information. That said, being a student of human nature, the more effort required to seek an answer, the less likely "newbies" are to know where to look.
sh7411usa
