I would turn everything to download and monitor ON, you can still limit it to Boyd County once everything is programmed.
Ok. wrote to scanner just Boyd County...see screenshots. Monitor and Download is ON
The screenshot...the law dispatch and Tac, and Talk are checked.Your post #55 screen shot, still does not including the service type that need to verify as others have mentioned.
No quick key assigned
Can you walk me through that...again...Im so sorry...I am taking this one step at a time...like suggested.
I know the feeling. I took care of the scanners in a TV station for 45 years.Our News Director is having a fit...
This is the file you sent. I hope this is what you're requesting.
Yes it is. Delete the Boyd County you just downloaded, and Upload this favorite list.
What you should see is F 0 (Favorite List 0)...S 1 2 3 4 (4 systems)..D 1,2,3 (Departments that are active on the system you're monitoring).
Once that is in, you can eliminate the other systems and isolate it to Boyd County based on the System number. ( 0.x Enter as an example.
We were using ProScan as a reference for screenshots. We have it closed now. But when I open it again...I will make sure that is set to OFF-
It appears that you are scanning while connected to Proscan.... If so, look at this box in the upper right corner of the Proscan window and be certain the "Resume Scan/Search" is set to "OFF".
Ok...this is where I am at right now...
Yes....Ok..is Monitor and Download both ON under profile tab?
Yes....
As a precaution, File .Save.
Then Write to Scanner (fingers crossed)
I see you have Quick Keys assigned to the systems. Are they on? Verify by going to the Favorites List Editor then the System Quick Keys Status tab. Like this image.
Stand by and let me check...I see you have Quick Keys assigned to the systems. Are they on? Verify by going to the Favorites List Editor then the System Quick Keys Status tab. Like this image.
