Uniden wav files player and organizer
phask
zanesville
I have a SDS100 scanner and did some searches with the scanner and have noticed that the Uniden scanner is showing site,TGID,UID information but Uniden Wave Player v2.0.9 beta is Not showing this information in the program can someone tell me how to get the program to show this information
Thanks for any help.
Steve
The pic you posted in the other post you have shows conventional for type. There wouldn't be any of those fields in a conventional transmission.
Saint
Fort Erie Ontario Canada
Yes I was doing a search for new digital systems and when the scanner found them I could see the information in the scanner come up but it was not showing up in the Uniden wave player, I will run my favorite list with digital systems and see if it works
Steve
Actually, they are conventional DMR that he showed and the UWP does display the Talkgroup and UID on some of those calls, now I don't know if the SDS scanners puts the information in the wav files (TRX/WS scanners do).
Saint
I have change to the Uniden Wave Player v2.0.10 beta and the talkgroup and UID columns are being populated the UID name column is empty because I did not fill this information in when I made the favorite list that I ran. the other information I see coming up on my Uniden sds100 scanner is not being saved to the Uniden Wave Player, this is the info not showing up. Will you be coming out with an update that will show this other information.
WACN
SITE ID
NET ID
SYS ID
WACN
SITE ID
NET ID
SYS ID
You need to remember, UWP only reads what is written on the recording, all it does is read the info from the recording. That information is not saved in the metatags on the recording. He can't display what isn't available. And, just because your scanner shows it doesn't mean it is being added to the recordings.
Saint
WACN
NET ID
SYS ID
Sorry the site ID Does show up
Saint
I was not aware of that, thanks for the info. my question has been answered.
mike36507
Robertsdale, AL
This is a great program, but the latest version keeps freezing up and has to be forced closed. I am running Windows 10 Home 64 bit
mc48
Monroe County, NY
Mine freezes up at times, but usually if I'm jumping around from one transmission to another while it's still playing.
I also notice that at times it shows UID and the UID name and at other times it only displays the name and if no name then only the number.
I tried this on my SDS100 & 200 and it was the same with both. I'm not sure if this is the player of it it's a quirk of the radios.
deim
Universal Scanner Audio Player developer
Saint Petersburg, Russia
Some times helpful add directory with your wav files to antivirus software exclusions.
Ubbe
Stockholm, Sweden
It's being doing that since the very first version and haven't increased or decreased in number of freezes during the different versions. It seems to help a bit by stopping the playback before selecting a new file, but it will still freeze.
/Ubbe
Reconrider
Inside the Galaxy
Radio Galaxy
Why does "Delete selected files" remove it from windows? Can you make it so it only removes it from the program?
I've noticed a small bug - the program freezes up when you try to play audio to quickly <- guess this isn't new -_-
Because the program was designed to use the files on the computer, not to control the scanner. That would be a lot of added coding for a free program to add a feature you can already do through the scanner.
That is a processing issue between the programming language and windows, it happens in many programs and is not a bug.
deim
Yes, bug with playing audio not new. Now i work on another project and i hope it will be fineshed it soon and fix some issues in this programm.
About deleting files. I think you will filter unwanted files and remove it from your PC. Files with 0 duration, files with noise and etc.
Reconrider
Inside the Galaxy
Radio Galaxy
I don't want his program to remove it from the scanner. I would like it to be removed from the program and not from windows.
Instead of deleting said file(s), we're simply removing the file(s) from his program, not the scanner
So you don't want to delete them you want to filter out certain calls. @deim just said he'll look at adding additional filters when he has time.
Kaleier1
I throught I was the only one suffering from program freeze ups. Usually happens if I click on a file to play it while it is playing another files. Still a great program.
