Unitrunker Unitrunker 2.1
GTR8000
NY/NJ Database Guy
BEE00
So is SDRTrunk and it works though.
Also, SDRTrunk shows and saves all messages and events. Does Unitrunker allow you to do that?
Conventional decoding was added to SDRTrunk after the fact, and now it does all sorts of stuff like analog FM, AM, etc. But again, SDRTrunk isn't Unitrunker.
How do you set that up please?
You don't, because as I stated, Unitrunker cannot decode conventional P25; trunking only.
jimmid
Broken Hill, New South Wales, Australia 🇦🇺
Pity.
Thank you.
Does Unitrunker log all the messages etc as a site I have looked at with SDRTrunk is showing crc errors and I would like to see what Unitrunker shows.
GTR8000
NY/NJ Database Guy
BEE00
Unitrunker can log control channel messages if you enable decode logging, but again, can't do anything with conventional if that's what you're asking.
boernegang
Boerne,Tx
Have a question. Where is the call history saved in Unitrunker and how would I view it??? I tried scrolling back when I got home but it only went back about six hours. Had a major police incident in my area today and wanted to see what Radio ID's logged into the LCRA system and what TG's were in use. Supposedly FBI and other Alphabet groups were in the area. I'm running Unitrunker 2.1
If you click on the TGID it will let you browse the history, only other thing I could suggest is look at the systems tab, open the system and go to radios then double click on "last seen" column to sort that way and scroll down to time frame you want.
Hopefully someone has a better way, as long as I've been using it I never thought about it, but I doubt it's saved forever as over the years it'd become a huge file.
krokus
Southeastern Michigan
I have never done this, but it was a way to have the GRE PSR-500/600 based scanners show transmitting radio id, on a non-trunked P25 repeater. You entered the repeater output as a trunked site's CC, from what I recall.
Unitrunker2
The 'History' tab on the Group, User, and Channel windows will give you this information - for that specific object. As pointed out above, that's the 'Calls' tab on the Site window. When scrolling far back in time, un-check the auto-scroll checkbox so you don't lose your position in the time line.
A broader answer to your question can be found here and here.
To examine the history data as a text file, you must first 'excavate' the data into text form.
dave3825
Suffolk County NY
Rick, is the following info still accurate or is something wrong with my install?
My Options Tab- Work displays a dot.
My Archive icon does open a location. C:\Users\Preferred Customer\AppData\Roaming\Unitrunker
Did this on 106 and 107
Unitrunker2
I'll fix that to display the real path. The dot is technically correct but not very useful.
boernegang
Boerne,Tx
I must not have something set right. The history for the TG's in use that day are blank even though the info tab shows hundred's of hits.
I stand corrected, I am not running 2.1. That probably makes a difference. Sorry for the trouble.
GTR8000
NY/NJ Database Guy
BEE00
Version 1 did not save the history when the program was shutdown. You were able to enable event logging, which would create a running log of activity, but as soon as the program were shut down/restarted, the history grids were all blank. Version 2.x changed all of that, and a permanent history is now kept. All of the site/channel/group/user history persists between software restarts with 2.x
boernegang
Boerne,Tx
Ok, I re-installed 2.1 but it does not see my dongle. It was working in the earlier version. When I click on refresh on the radio tab nothing comes up. I followed the instructions to perfom zdag but that did not help either. My dongle is a RTL-SDR V3. It shows to be a supported SDR. What am I missing??
Unitrunker2
The program is very picky about how Zadig is used to assign the WinUSB to the USB device.
If you assign the driver to either of the two interfaces, it won't work. If you assign the WinUSB driver to the whole device (which requires unchecking a box in Zadig) - then it works. See here:
JAWSxs
Thank You! I'm on hour 3 and wits end. I just couldn't figure it out why they weren't showing up. I had an older version working perfect years ago. anyways, thanks for the link!
