Unitrunker stops while changing control channels
shajoe44
North Augusta, SC
How can you keep Unitrunker running while changing to a different control channel? Everytime I go to a different control channel, I have to restart Unitrunker. What I was wanting to do is scan thru the different 800 frequencies and see what was in my area.
morfis
shajoe44 said:
Will all my files be saved if I install version 5 over version 6.
You will need to uninstall the beta 6 version before installing beta 5. Data files should not be affected BUT it always pays to create back-ups of files on your computer you consider important :)
You'll lose the CFG file (with all the receiver settings). Everything else will remain.
Liverdog
I'm having good success scrolling through memory channels on my scanner manually, each having a different control channel, and UT rebuilding the screen each time. These are all P25 systems. I'm using the 6th beta.
