V1.30 G2-G5 Firmware Released
mitbr
Tampa Bay Florida
I downloaded the firmware so how do I get on the pager.
Make sure you have saved your codeplug before applying the firmware update. Close the pps click on the downloaded firmware exe while your pager is connected to your PC follow the instructions!!
Tim :cool:
Uni1
Unication Representative
DFW Texas
thanks i have that already if you read what i just wrote, again my Question is where is the the hold button on the the G5 to push to activate the hold Button ??
Bottom of the screen after you enable it in the PPS.
cookmaster
Tucson,Arizona
thanks i will keep looking for it so far i am not seeing that on my G5 at all being displayed when receiving a transmission on my local Truck system!
lebrunmn
Retired... Get off my lawn!
Hampshire County, WV
Upgraded to 1.3 and the new programming software. Still no Bluetooth. Go figure.
My airpods work just fine with 1.3... there is a three-beep thing that I'm trying to eliminate at the beginning of some transmissons. I'll check the PPS to see if there's a setting I can change. But set up was a breeze.
W4KRR
Coconut Creek
The issue of the randomly disabled external antenna when pager is inserted in the charger has apparently not been fixed. At least not on mine; inserting the pager causes improved signal for a few seconds, then it goes to "Out of Range" with no reception.
cookmaster
Tucson,Arizona
i will recheck everything when i receive a transmission while scanning a trunk system my G5 is showing nothing its blank a the bottom no Hold or block!
Uni1
DFW Texas
I'm not familiar with your issue. Have you tried multiple amp chargers? Have you cleaned the contacts on the bottom of the pager? Eraser works well for cleaning.
lsh1885
Orlando, Florida
I tried to program my G5 and it said cannot program a G4 profile onto a G5. I don't have a G4 anymore. So I am not sure why it is saying that.
JASII
Memory Capacity
Does the Trunk Hold and Blok work when the Unication is in the Trunk Search mode or whatever they call it when you monitor everything on a trunked system?
Uni1
DFW Texas
Read the profile from the pager in C / C3. Make the changes by opening the profile you just read. Write back (program) the pager.
