mitbr
Yes it does! in monitor mode.Does the Trunk Hold and Blok work when the Unication is in the Trunk Search mode or whatever they call it when you monitor everything on a trunked system?
No.Is there a way to stop the flashing green "TGID Removed" message box when blocking a TG during a scan?
You have to enable the feature in the pps file then reprogram your pager. It took me a little bit to find it. But tab 8 as others gave said. Scroll down until you find the Section for TG hold. Then click the box next to enable. Once that is done, reprogram your pager and it will show up.i will recheck everything when i receive a transmission while scanning a trunk system my G5 is showing nothing its blank a the bottom no Hold or block!
I did all that but my pager still says v1.20
Here: Unication Auto↑Upwhere do I find the firmware updater
Any chance the file got corrupted while downloading or didn't fully finished downloading?When I click on the new firmware 1.3 exe file in Window 10, I get this message:
What is wrong? Thanks.
BTW, I have downloaded and installed the new PPS with no problem and backed up my existing programs on both my G4 and G5 pagers.
thanks all for your help with the Hold button it was an error on my part, now i can use that, i now only thing left to do is firure out how to get the TG Block going in the software now,i have not seen it yet, can some tell me where is it in software so i can get that going too?
Even though it looks like the file downloaded (Firefox tab scrolls green when I click Save File), the file size says 0 KB in Explorer. I have tried it 6 times now with the same result. I'll try it again in the morning Any other ideas greatly appreciated. Thanks.
I am having the same results with TG hold timer countdown with my G4. I have my screen timeout setting at 30 seconds, TG hold at 2 minutes, after screen times out and goes dark the timer countdown stops. It will resume countdown if I bring up display manually or if TG resumes activity. I have not used the TG block as of yet though so I cannot comment on how it functions.
