Version II of Stryker 955 AM/SSB
slowmover
Fort Worth
Mounting antennas to vulva mirror lips might be another story. I’m told the OEM mounts are plasti-fragile.
Here’s how fourstringburn runs a screwdriver out west:
If you’ll do a search on him at WWDX you’ll find a pic of his using a JBC545 mount on the lower starboard mirror arm and with a SS extension running a SIRIO 5000 and long stinger. (See all media).
He reported VG performance AM & Sideband. Until lightning took it out.
One of these new-board radios in a TRC-1 & a SIRIO 5000 ought to be killer.
slowmover
Fort Worth
Only reason I'm considering a back of sleeper mount is, as you can see in profile pic, I pull flats with a midroof. In order to get numbers right on antenna I had to lean 6' Skipshooter forward 45 degrees. Not crazy about that and feel like it may hamper transmit. I really need to get off my arse and get a field strength meter! Power is the same as yours. Battery ground straps on doors and sleeper cab shock.
JD
Yeah, Scott and some others like to claim that bull-horns angle crap works best. I haven’t heard yet a rig that was proven.
The Mexicans love that look with some big coil antennas. Sound great the first mile running a MR X custom.
Tanker or Van: screw cab-back antenna mounts, IMO.
You load up some metal isn’t very tall on that Flat, and . . . .
You were in an aluminum-body large car, I’d say, yeah, try it with a whip gets close to 14’.
CDX951
NE Ohio
Previous radio on top of dash held by 3M heavy duty velcro.........
I really like this radio!
I can remove or change radios in 5 minutes!
Also..............the WM CLRspkr has been retired to the closet due to the dsp NR in new radio. Will never get rid of it though!
JD
slowmover
Fort Worth
JD
Did you try the DSP Speaker, though?
Mid-afternoon is damned tough.
(Needs to go in your civvy vehicle).
Is the Q5 now the big truck backup radio?
CDX951
NE Ohio
Works the same as the internal dsp. It is adjustable 1-5 I find 3 gets it done. I wouldn't be without it with any other radio! It works really great with my Quad 6!
JD
slowmover
Fort Worth
Yeah, DSP is the game-changer!! (What is called NRC on these new-board radios).
slowmover
Fort Worth
They got me!!!!!
The quest begins anew!
JD
Sweet ride!
Getting past the multiplexer is what would irritate me. AND how to mount a decent pair of antennas.
Volvo/Mack is the one tractor I haven’t done an install.
Keep this rear fairing mount in mind past a bird or Z-perch also by TOP GUN TECH at Bobs CB (mount in orientation shown)
Top Gun Technologies (TWISTED-L MOUNT) - Ultra L-Bracket, ALL STAINLESS STEEL, SS Mounting Hardware Included, Mobile Antenna Mounts
Rabbi P-C did a pair off the fairings on a steel-body Volvo (though not these brackets). He’s near Allentown, PA if you get that way (daily into Long Island). Might be persuaded to help (he’s offered with several men).
slowmover
Fort Worth
Bobs is carrying these. See WWDX thread. I’m looking forward to getting one
KMG54
Easley S.C.
If that's the starboard side of his truck and you believe it I hope I never meet you on a two lane road! Coming from a USCG 100 ton merchant marine.
slowmover
Fort Worth
Good one.
Distance from fairing exterior is less than the outer edge of the mirror.
