When I’m on i4 and i95 (north and or east in the county) I didn’t pick up much on the p25. I don’t know bay is active or something changed.
last I check the CC for Holly Hill site is on 851.1MHz. I searched ULS and couldn't find anything. All I heard was fire paging tones on patched TG 301.
But I think Haris Systems Handel.
The CC for Holly Hill site is on 851.1MHz.
Sorry, I didn't finish my train of thought, that's what happens when u write posts at 02:00 Hours. What I was trying to say is I think some harris systems Handel P25 Control Channels differently, in the sense that all of the frequencies in use can be designated CC at any point. But if I'm wrong I'm sure someone will correct me.
I'm Interested in where you got 851.1 From. It's not any of the current Frequencies in use on EDACS or P25?
Not sure if those are holly hill site
On rrdb shows 2 as Unkwon voluisa.Then what site could it be?
Okay. I did a search on 851.1 nothing showing up expect for Nextel holding.Yes im aware, but im saying if billy got a cc of 851.1 and its show 2.2 and if its not the Holly hill site then what is it.
also, DSD should just find the CC unless 851.1 is one of the alt CCs.
you're all good! I was dragging SDR# around 850MHz and found 851.1. DSDFL decodes it as 91F82.00A-2.2 with simulselect super/subgroup patches such as
CC is 851.1MHz@billy2047 on 2.2 do you have all the voice and cc/alt freqs? Not sure if those are holly hill site
it was pipe from SDR# to DSDFL using a virtual audio cable.did you pipe your audio from SDR# to DSD. Or did you use the FMPx window
I did a freq search for volusia nothing with those freqs. I did a state search in those 3 freq appears to be Bervard county might be picking up.CC is 851.1MHz
Voice CH1 852.0875 -1 or 2
Voice CH2 853.1125 -1 or 2
both voice CHs are in phase 2, 1 or 2 is the slot.
humm interesting.. so Volusia is using Brevard's (or Flagler) frequencies for its P25 system???I did a freq search for volusia nothing with those freqs. I did a state search in those 3 freq appears to be Bervard county might be picking up.
851.1000 WPJS363
852.0975 WQWU401
853.1125 WNWQ632
On dsdplus when using event log screen once awhile a call sign might pop up with a freq.
Maybe volusia is joining the Bervard system case of mutual aid for either counties. Flagler county not sure. It is possible all 3 counties joining on one system like Polk county has done with hardee highlands desoto. Just keep a eye out on the fcc license pop up on the event screen than it will pin point who that belongs too.humm interesting.. so Volusia is using Brevard's (or Flagler) frequencies for its P25 system???
10-26. Thanks!Maybe volusia is joining the Bervard system case of mutual aid for either counties. Flagler county not sure. It is possible all 3 counties joining on one system like Polk county has done with hardee highlands desoto. Just keep a eye out on the fcc license pop up on the event screen than it will pin point who that belongs too.
All I heard was fire paging tones (occasionally fire dispatch). there were radio affiliations but most were denied only a few radios made it through
851.1000 WPJS363
852.0975 WQWU401
853.1125 WNWQ632
