What is TriMed On?
scannerizer
Wherever I may roam
I thought TriMed was on the TRBOWEST system. I loaded their TGs into the TRX-1, but haven't herd anything the best 30-45 minutes. They're not encrypted, are they?
devicelab
Whacker Extraordinaire
Nowhere in WA
Well that's your problem. Site 58 isn't Seattle. You need to load up Gold Mtn, Tiger Mtn and Columbia Tower.
scannerizer
Wherever I may roam
I have both of those. It just blinks the square S and the signal walks up and down in the display. As it seems, the LCNs were off; just checked the LCNs and updated them, so we'll see...
devicelab
Nowhere in WA
It won't matter as the TRX scanners do not trunk track DMR or NXDN systems. They only scan the frequencies and color code/RAN code.
Also you should note that it's the weekend and [in general] the traffic dies down especially over a holiday.
Littledude
Everett Wa.
Trimed is utilizing a 4G/5G based radio system now in conjunction with a CAD system. There is Motorola XPR radios in the rigs, but I believe it is used for the VHF H.E.A.R radio.
scannerizer
Wherever I may roam
And I was so excited to get some TriMed on the TRX-1. I just missed a peep on my way in my room. It seriously stinks because I was hoping to have a little more to listen to.
Littledude
Everett Wa.
Let me know if you hear anything on the channel, I am curious now. But I know for a fact that they use the cell based PTT/radio for sure, I can confirm that (if you catch my drift). 😉
scannerizer
Wherever I may roam
Half hour ago, I heard dispatcher calling a "71," and telling they are Code Green. Tey probably dispatch on the PTT and then keep in touch with a dispatcher via radio. The dispatcher was telling them to return to quarters.
Strangely my TRX-1 let me load in the TRBOWEST (i.e. no "S" like with PSE's system). One would make you think it can track DMR in that case. I also updated my library and that seems to work better for me, in general.
Wilrobnson
Rock or Something
Object-oriented
I have no problem tracking DMR and NXDN with any of my TRX radios. Others are not so experienced.
Also, don't use the database.
I guess welcome back from Arizona, if you were actually there.
scannerizer
Wherever I may roam
Visiting for my B-Day. Will fly back on 2/27. By the way, what does Falck Ambulance serve? They're supposedly a Danish ambulance company. Has anyone ever listened to them?
Also, are you suggesting that I program TRBOWEST manually?
Wilrobnson
Rock or Something
Object-oriented
Good to know that WSDOT is outsourcing to Arizona, I guess. Falck used to be Pierce County north when I flirted with working there.
I program literally everything manually, I strive to use the DB zero percent of the time.
