BCD436HP/BCD536HP: Which Sites to Program
JethrowJohnson
I love P25
Marietta OH
Hi everybody. I was just wondering if I should program all of the sites in the surrounding counties or only program one site for each system? I'm at the Ohio/West Virginia line so there's both MARCS and SIRN and I'm not sure if I should program every site in the area or just my county. Thanks for reading.
JethrowJohnson
I love P25
Marietta OH
You know a Simulcast System with multple site/towers looks like one big site... You cant single out individual sites/towers from it...
I know. That isn't what I meant. On all of the counties on the Ohio side for MARCS, I only have the Washington County site (or cell if that's what ya want to call it) but for Wood County WV, I have the Parkersburg, Vienna, Rockport, Belleville, Statewide Portable Site, and WVRRT Portable Site all programmed in and I wasn't sure if that was the best way to have them set up if I went outside of Washington County with it.
wtp
Port Charlotte FL
and the old line of "the more you try and listen to, the less you will hear", comes into play.
at home i have many radios, when i go out i have at least 2 scanners and the wife has her's.
with more radios you can hear more.
RandyKuff
Lorain, Ohio
You talking like putting them in the same fav List... Thats a no no...
JethrowJohnson
I love P25
Marietta OH
I don't think I can afford that many though.
JethrowJohnson
I love P25
Marietta OH
If different System's... Different Fav Lists...
No I have each trunked system in its own List. I have it set up like this:
List 0:
System 0: Washington County/System 1: Ohio MARS-IP (84)
List 1:
System 0: Noble County/System 1: Ohio MARCS-IP (61)
List 2:
System 0: Athens County/System 1: Ohio MARCS-IP (05)
List 3:
System 0: Morgan County/System 1: Ohio MARCS-IP (58)
List 4:
System 0: Monroe County/System 1: Ohio MARCS-IP (56)
List 5:
System 0: Wood County/System 1: WV SIRN (54)
slayer816
NE Louisiana
RandyKuff
Lorain, Ohio
I prefer all my sites in one system, one FL...
However I do arrange them in certain order and use site hold / QK to only scan what I want - when I want, at any time usually within a second. It's the best way to efficiently use the programming IMO
Easier to Read BCD436/536HP Digital Scanner Manual Order
Easier to Read BCD436/536HP Digital Scanner Manual Quick Keys
Easier to Read BCD436/536HP Digital Scanner Manual Holds
Having different Systems with different Control channels running at the same time in a fav list will slow the scan speed...
If you are only running one System at a time thats different...
JethrowJohnson
I love P25
Marietta OH
Having different Systems with different Control channels running at the same time will slow the scan speed...
If your only are running one System at a time thats different...
So most of the time, I would only have List 1 (Washington County conventional and MARCS) enabled for scan. I have the other counties only for mutual aid incidents. So, for example, Reno Volunteer Fire Department responded to a report of a structure fire earlier today, and the dispatcher called Wood County to have Williamstown Volunteer Fire Department respond for automatic mutual aid. That's when I would enable List 5 (Wood County conventional and SIRN) for scan. (By the way, that incident turned out to be a false alarm and Williamstown was canceled before they got into our county.)
RandyKuff
Lorain, Ohio
In your case if only monitoring one System at a time... Using Quick Key's on the sites would work too...
RandyKuff
Lorain, Ohio
If your list numbers are the Fav list numbers... Indeed, easy peezee... Punch the number and enter to turn them on or off...
JethrowJohnson
I love P25
Marietta OH
In your case if only monitoring one System at a time... Using a Quick Key's on the sites would work too...
I also have quick keys assigned to all my Lists and Systems, but I'm still trying to get used to that th
Well, I tried that just now and it just beeped at me like it was an invalid number or something. I pushed 5
You do have fav list quick key numbers assigned correct...
Yes, but I pressed 5 and E/yes and it beeped at me as if it were an invalid number or something. I usually go into Menu>Set Scan Selection>Select Lists to Monitor>Favorites 5: On. And that's how I enable/disable my Lists until I learn how to use these quick keys.
