BCD436HP/BCD536HP: Which Sites to Program
RandyKuff
Lorain, Ohio
Beep... Then you dont have the Quick Key numbers assigned to your Fav Lists...
Putting a 5 on the Fav list name is not the way to do it... Tats fine for keeping track of them...
Do you have Sentinel software...
JethrowJohnson
I love P25
Marietta OH
Your MARCS sites in your list... Are those in completely different areas...
So for MARCS, for all of the counties, I have the Washington County site cell programmed for all of them. But when we took a short drive on I-77, we went into Noble County and I had no signal from the control channel beca
Then why are they showing at the top of the screen?
JethrowJohnson
I love P25
Marietta OH
It worked before, I think I just forgot how to use them. I need to keep practicing.
RandyKuff
Lorain, Ohio
Shows at the top of the screen because it's showing you have a list in that position...
Doesn't mean it has a QKey number...
You could assign any QKey number to that position...
RandyKuff
Lorain, Ohio
Wait, I might be wrong on that posted above...
Are you using Sentinel?
Just like the old Download and Monitor that need to be checked when uploading to the scanner so does Quick Keys need to be checked in your Profile settings...
JethrowJohnson
I love P25
Marietta OH
No I just have a tablet. No place for a cable to program it by computer. All done manually.
RandyKuff
Lorain, Ohio
OK, you must have used 05 instead of 5... Didn't think you could do that...
On my SDS's, I would just hit 5 and enter...
I used to have a 436 and it worked the same way... Tap 5 once and enter...
JethrowJohnson
I love P25
Marietta OH
Just looked in my Sentinel... I entered them as single digits,,,
So should I just leave MARCS as it is and delete all the sites for SIRN except for the Parkersburg site, or vice versa, and I don't suppose it would work if I programmed the Washington County MARCS site for SIRN, would it?
RandyKuff
Lorain, Ohio
Programming them in different systems within the same Favorites List works just fine. Just assign Quick Keys so you can toggle them on/off.
RandyKuff
Lorain, Ohio
What ever will work best for you to navigate...
JethrowJohnson
I love P25
Marietta OH
What ever will work best for you...
Well that's what I'm unsure of. I don't know if it would work better to have multiple sites or just one, or to have multiple but, like my Lists, assign quick keys to them and only use them when I'm in that area?
RandyKuff
Lorain, Ohio
If those MARCS sites you showed in your Lists... If they are different sites (different control channels), I would keep them
in seperate Fav lists... That way you can have any combination on or off at the same time...
JethrowJohnson
I love P25
Marietta OH
Okay, so I'm still in the process of programming this scanner, so when I finish you mean I should create extra Lists for the other sites and turn those Lists on when I go into those counties? And Wood County has multiple sites (not simulcast) so should I do the same for that?
RandyKuff
Lorain, Ohio
As long as your not monitoring TWO different control channels at the same time in the same Fav list, you can combine them...
And I would use Quick Key's on the SITES then to turn them on or off... But no more than one site on at a time in a list..
JethrowJohnson
I love P25
Marietta OH
And I would use Quick Key's on the SITES then to turn them on or off... But no more than one site on at a time...
Okay. Thank you. I think that's what I was trying to figure out. Thanks again! 🙂👍
