ProScan: Why do System Quick Keys only show up for Conv Systems?
Pr999
WRYF747
Plainwell, Michigan
Why don't other systems like DMR & P25 not show up when setting the quick keys? Are they separate from each other?
ProScan
Software Provider
Ontario, Calif.
Because that's the way the scanner is. You didn't advise on the scanner type but I'm sure you are referring to the DMA types.
The DMA type does not use System Quick Keys on trunking systems at the system level. They use Site Quick Keys.
If you go into the scanner menu and look at a trunking system, you will not find System Quick Keys at the system level. Again this applies to just the DMA type of scanners. The BCDx36HP and SDSx00 uses System Quick Keys on trunking systems.
Pr999
WRYF747
Plainwell, Michigan
Sorry, the BCD996P2.
Then how do I access trunked and digital systems without the quick keys?
ProScan
Software Provider
Ontario, Calif.
Assign each site a Site Quick Key.
See this link and the pdf file.
Another link. Search for 'Quick Keys'.
ProScan
Software Provider
Ontario, Calif.
I just figured out that trunked and digital systems only use number tags, how do I use them?
Number Tags are different then SQK's. Basically Quick Keys turn off and on systems/sites. Number Tags are shortcuts to go directly to a system or channel.
Read the Easier to Read manual that was posed in #4. Quick Keys and Number Tags are explained
tvengr
Well Known Member
Baltimore County, MD
Here is a PDF file which will answer all of your questions about using quick keys:
  • Uniden Scanner Quick Key Instructions DMA.pdf
ProScan
Software Provider
Ontario, Calif.
Trunking systems uses SQKs at the site level. Conventional systems can be a digital system too and is not a factor in the use of SQKs.
ProScan
Software Provider
Ontario, Calif.
In ProScan, click on one of the site nodes (left side) then you should see the 'Quick Key' option on the right side. Pick a number. Do that to all the sites you want SQKs assignments. Upload to the scanner afterwards.
Firebuff66
CT
It does, if you go to the database and expand the tree you will see all the QK.
As said above this is something very easy to look up in many different places, including the help in ProScan
