WiFi... How are you connecting to your SDS200
WX4JCW
Stow, Ohio
So forgive the dizzy inducing movement of the camera and the nosedive you take when I had to put the camera down to detach it from the dock, I was using my iPhone one handed.... Here's a quick clip of what Proscan looks like running on a Win 10 tablet via a Vonet wi-fi bridge on the scanner. The audio on the tablet is crystal clear, in fact the scanner audio is turned all the way down but you can still here masive buzz in the background, ON TOP of the dispatch audio. Like I always said, the firmware update only shuts off the audio between transmissions, it does nothing to the audio on calls, you still have the buzz once transmission starts. I then turn down the tablet volume and hold the camera near the EXTERNAL speaker (I'm so tired of people saying the buzz is only on the internal speaker).
Note, this is a large file, start it up then hit pause so it can start coming down or you'll have no audio.
http://jenniferbond.com/images/proscan-tablet-buzz.mov
People continue posting reviews saying the buzz issue was fixed with the metal chunk hack and firmware, I disagree.
By the way, Uniden Siren works great if you’re on an iOS device.
No buzz here
Sent from my iPhone using Tapatalk Pro
frazpo
SW Mo
I have had Proscan connected through the Vonet bridge on my internal network. I was working on configuring audio and webserver portion and now,,somehow, I have audio but no display of the scanner through freescan. Whether or not related I will ask,, Do I set the scanner to DHCP and the put the vonet bridge as a static address or the opposite? That seems to be the last settings I touched prior to losing the display. Like I said I had it ALL working earlier. But not to the point of using the web server.
***EDIT***
Seems to be on the computer side. Another computer works fine.
jjbond
Banned
Banned
***EDIT***
1: Plug the vonet into you laptop/computer to set it up per the instructions (basically you plug it into your ethernet port, then log into it's GUI/web page and look at the list of wi-fi networks, enter your password and it then locks onto an IP, Subnet, Default Gateway and DNS. At that point its acting like a wifi card in your computer.
2: Logged into my cable modem, and went into the wireless client section and looked at the list of IP addresses that had been given an IP from the cable modem's built in DHCP server, it was 192.168.0.28. I then went to the DHCP section where you can also assign a static IP, I did that, based on finding it in the client list, I had the IP address DHCP handed out, but I also put in the Mac address of the Vonet. This locked in that IP address as belonging to Vonet.
3: Keeping in mind I'm still using Vonet on my Macbook Pro as my wifi card, Vonet's DHCP server handed me an IP, I noted the range, subnet ect to be sure it was in line with my other network stuff, wanted to be sure it had not thrown me onto a subnet.
4: Unplugged Vonet's cat 5 connection from my computer, put it in the front of the SDS200, plugged in the USB for power (although I'd probably go a separate source as each time I FTP's up to it or the power cycled, so did the SUB V+ so Vonet rebooted and it's not the fastest coming back online and you risk getting the wrong IP etc...
5: Vonet's lights are flashing, my Macbook Pro is back on its' own wireless connection. I can see on my cable modem (logged into it) that Vonet's woken up and been assigned her IP address of 192.168.0.28, packets are pumping, I look in the SDS200 settings at the LAN settings, "Show IPs", I see that everything looks good, matches what's on the cable modem admin page (I think actually it was one digit higher, I recall my cable modem pushing and my reserving 0.28 but my SDS showing 0.29 as the Vonet acts as a bridge (I've since taken it off). I was then able to connect to it via Proscan both data, FTP Write/Read, as well as Audio with loopback for local audio. I did not open any ports on my firewall as I'm not streaming. Keep in mind, at this point I've told SDS to use "AUTO (DHCP)" in the "Set IP Assignment" section so it's grabbed whatever IP Vonet cares to give. I'll change that shortly. While in the LAN settings, make a note of the IP address she'd previously been assigned via DHCP, the Subnet Mask, the Default Gateway. Like I said, your IP address may be off by one or more but it's important that the items in red are correct.
Note: this is where it's best to power the Vonet from a USB power bank while you're setting this all up, every time you change your IP settings on the SDS, it reboots the scanner, and as a result, the front panel USB port.
6: The DHCP server in Vonet was working great, gave SDS an IP, so once I new everything was working great, I changed the way the SDS gets assigned an IP address from "AUTO (DHCP)" in the "Set IP Assignment" section to 'Manual' in the same section. I then had to enter in the IP address she'd previously been assigned, the Subnet Mask, the Default Gateway etc. Once I set it to 'Manual", it rebooted and came back online.
Note: The 192.168.01. ou see there for Gateway (Default Gateway), is the actual IP address of my cable modem, same IP address I log into when i want to log into make changes to it's setup.
Note: I've taken the Vonet off, only because it introduced ticking sounds on top of the already famous buzzing sound as it was so close to the radio. I could put an extension on the Cat 5 but It was just as easy to run a cable from an Apple Airport Extreme I have close by and connect that to my cable modem like I did the Vonet, just acting as as bridge.
The audio difference is incredible.... LAN is awesome... and I will say, as much as the Vonet method is awesome, if you can run an ethernet cable, you'll be amazed how much quicker it is... the Vonet still took a while to grab and assign IP's etc and seemed finicky a bit, reliable but a bit finicky... Cat 5 blows it out of the water.
I may have missed a couple things but I probably over did this explanation anyways, you sound like you've almost got it working.
Have fun
Jen
jjbond
Banned
Banned
.... I believe I also read somewhere that you can do a direct connection from phone over wi-fi to Vonet into scanner or from tablet, PC etc... without the need of a router, if you wanted to dedicate an item as a remote head, keeping it off your regular network etc, but didn't look into it.
My comment about finicky was directly related to being able to get Proscan to recognise the IP in the URL setup area of the application, at times it took a while for Proscan to realize the scanner was out there on the network. I don't blame that on Proscan as much as the fact that each time Vonet did a reboot (while I was making changes in the IP config section of the SDS, cus her USB port went down ) she's a slow one to wake up and starting screaming "I'M HEEEEEEEEERE, LOOK AT ME, LOOOOK AT MEEEEE KIIIMMAY, KIMMAAYY LOOK AT MOI (for my fellow Kath n Kim loving aussie friends)... PAY ATTENTION TO ME.... I GOT SOME PACKEEEEEETS FOR CHEW!!!!" Somethign all but eliminated with a direct connection but once she's awake, if you leave her awake, you'll be fine.
frazpo
SW Mo
OK. Im all good on using proscan to manage and listen to the scanner now. No onto setting up the web server. Im assuming I open port 5000 on the computer that I am using to connect to the scanner with? Doesnt seem to be taking at this point.
jjbond
Banned
Banned
Well normally the response I'd teach my kids to say would be "Wow, thank you for taking the time to write such an exhaustive and detailed explanation, I appreciate it", not "Ok", before they felt justified in asking another question, (it tends to make them want to continue the effort, where others would simply say, "read the manual" (inside joke, disregard)) but I'm old fashioned that way so no problem, it's the Canadian in me, we're overly polite .. ;) :p
Sorry I got caught up in your question "Do I set the scanner to DHCP and the put the vonet bridge as a static address or the opposite", I didn't see you ask one about your port numbers or the http server, but perhaps you just got to that point, good job.
Good luck in your endeavours, I'll let someone else take the next question.
Jen
frazpo
SW Mo
Well I'm doing a dozen different things today and have been hopping in and out of scanner mission. I was taught good manners and would have thanked you appropriately once I got to a resting point. So.. thank you for your in depth explanation. I appreciate it.
jjbond
Banned
Banned
I'm just playing with you, I'm not that thin skinned... :) I'd continue helping but as I said prior to your "Ok", I'm not opening a port and streaming so am of no service...have fun.
Jen
frazpo
SW Mo
I meant to mention the additional popping with the vonet. I get that also. It may go along with the infamous hum. If you use a separate power source other than the scanner you do not hear it.
jjbond
Banned
Banned
Good find... yup, ground loop noise, makes sense considering all the other similar sounds we're hearing.
WX4JCW
Stow, Ohio
Jennifer you had too much sugar or Caffeine today lol
eaf1956
Evansville, IN
I don't get that with my Vonet and it powers from the scanner.
Sent from my SM-N960U using Tapatalk
frazpo
SW Mo
Do you have the ground loop hum? It seems to be associated with that. I also noticed some affect on a vhf nxdn system. Missing transmissions when connected.
eaf1956
Evansville, IN
If it does I can't hear it. But I'm 62 and my hearing isn't the best after years of Jet Engines in the Air Force.
wb4sqi
Cincinnati, OH
OK, read all of the above and think I understand some, not all. I received my SDS200 today and it stays in my office/ham shack and is within Ethernet reach of my home router.
All I want to do is be able to monitor my 200 in any room in my home, either by IOS app or DMR hotspot or ????
Options I have available:
the Uniden WiFi dongle from my 536 and Siren app.
I have a spare DMR hotspot running from a Raspberry Pi, maybe use that to rebroadcast to a DMR handheld?
SDS200 hardwired to my home router? Not sure from there how I would listen, iPhone, iPad via what app?
I do not want to broadcast to the internet, just be able to listen in my house.
Thanks in advance for your positive and helpful comments.
Nick
WB4SQI
