Will VP8000 allow P25, DMR, and NXDN at the same time?
DeoVindice
P25 Underground
5150 Level
Our Province wide Harris system has a ton of fire agencies running Kenwood/EFJ as well. We'll at least the ones that don't buy the bottom barrel Harris radios. Always easy to tell those users by the really crappy audio.
Now I'm curious - is that only occurring with the lower-tier Harris portables?
Cortexian
I would be an "authorized user" and not trying to "passive scan" but regardless, I would still like a correct answer.
Ok, will it *scan* 700/800 P25, and VHF, UHF NXDN, DMR and Analog?
This is all relevant to the title of this whole thread
You cannot program any trunking systems into the radio without the appropriate ESD/ESK present. If you have that, there is no limit to what you can scan. That is the only caveat.
So yes - You can scan any combination of analog, P25 conventional/trunked, DMR conventional/trunked, and NXDN conventional across any of the RF bands supported (V/U/7-800).
Eagerly awaiting the 25.2 subscriber software release. Been told it should be this month some time. Can't wait to try out NXDN and Broadband Voice / Kenwood Boundless or whatever they are calling it.
Project25_MASTR
Millennial Graying OBT Guy
Texas
And how did you manage to get the key?
I have this little blue USB dongle that has Viking molded into the housing that I plug into my computer whenever I'm programming Viking radios. Just like I have a little blue USB dongle that has batwings molded into the housing that I plug into my computer whenever I launch APX CPS.
K2NEC
5F6
Actually it has an "i" on it ;)
I was trying to make the point that if you have a legitimate key, theres no point in doing NAS. At that point its just scanning trunking for whatever youre authorized for
DeoVindice
P25 Underground
5150 Level
Because they have no audio shaping capabilities.
I'm mainly curious whether it's an issue with all current Harris portables or just the XL-45/95P low-tier models. The one Harris-equipped jurisdiction in my local area has awful shrill audio; Motorola and Kenwood gear sounds noticeably more natural.
Project25_MASTR
Texas
Functionally though when you are scanning two different systems, whether it be two trunked systems or a conventional and trunked system, you are doing NAS.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Honestly, I can't remember.
AM909
Radio/computer geek
SoCal
Functionally though when you are scanning two different systems, whether it be two trunked systems ... you are doing NAS.
Scanning two trunked systems, does the radio only affiliate with one system, so it's NAS for the other? What if you need it to affiliate with both to ensure that the site carries the talkgroup you need to hear?
... or a conventional and trunked system, you are doing NAS.
Why?
Thanks for helping us non-MASTRs understand. :)
KevinC
32D2T/957.282
I'm everywhere Focker!
Registering/affiliating to multiple sites/systems/platforms would considerably increase the time spent on each one and would make scanning between them next to useless. I have no idea how this radio works, but I'd highly suspect and hope it doesn't do that.
AM909
Radio/computer geek
SoCal
Yeah – it certainly couldn't go through a whole register/affiliate handshake with each system before moving on to the next system. I thought it might register/affiliate once with each system and then just listen to each CC long enough to get the current status info for the non-CC channels.
MTS2000des
5B2_BEE00 Czar
Can confirm having used a VP8K for a year that when using RWS, there are no affiliation requests sent to a zone controller, nor does it respond to commands in RCM when scanning a P25 trunked system, so it is truly "no affiliate" scanning. BUT, as mentioned, one needs a valid aKey to program any P25 network- and- womp womp womp...no 35 year old DOS programs are out there for forge them. Only given to system owners by EFJ/Kenwood.
n7maq-1
Oregon
I regularly scan two P25 systems, conventional and DMR with RWS. I have two priority channels, one conventional and one trunking and the VP8000 does a great job.
WB5UOM
Of course it does a great job, it's a KENWOOD !
