Heard that Windsor was in the process of changing their system... but don’t have any particulars. Anyone else hear this?
Thanks. At first glance site 3 looked to be on the airport, but is just off the property.CLMRN has a site at the airport, Windsor does not. There are 3 sites (proposed) all in town.
FCC Callsign WRDX585 (WINDSOR, TOWN OF)
FCC Callsign WRDX585 (WINDSOR, TOWN OF)www.radioreference.com
Thanks for the update. Has anyone actually heard the control channel? Wondering how the programming Is done without TG’s and service assignments. I assigned a service and set “Search” for ID but I’m wondering if I’m going about it correctly. I intended on capturing the TG’s when I heard transmits and assign the dept names, that’s not too hard to discern but I first need to receive the system.The system is transmitting, and has been added to the database
Windsor Trunking System, Windsor, Connecticut
Windsor Trunking System Profilewww.radioreference.com
As long as it's set to "ID Search" and not "ID Scan", it should automatically pickup any talkgroup when they start talking.Thanks for the update. Has anyone actually heard the control channel? Wondering how the programming Is done without TG’s and service assignments. I assigned a service and set “Search” for ID but I’m wondering if I’m going about it correctly. I intended on capturing the TG’s when I heard transmits and assign the dept names, that’s not too hard to discern but I first need to receive the system.
your located in Wethersfield correct?As long as it's set to "ID Search" and not "ID Scan", it should automatically pickup any talkgroup when they start talking.
I get a weak signal from one of my computers, but it does pick up the system. I'll keep an eye on it and see what gets logged.
Yes, I'm in a little bit of a valley thoughyour located in Wethersfield correct?
Great! Thanks for the help. I was under the impression ID Search/Scan were different than TG Search/Scan... I guess if I add a TG, something made up, I might then get the options of TG Search/Scan? Or does the scanner (SDS200) default to Search when no TG’s are listed? I see from the automatic download from RR that only the control channel is listed ... while I understand that’s all the scanner needs to follow the system, would it hurt to add the other frequencies I see listed for the system? (I don’t think that Logical Channel Numbers apply for a P25 system but I entered them in the order they were found just in case.As long as it's set to "ID Search" and not "ID Scan", it should automatically pickup any talkgroup when they start talking.
Chris, Are you referring to the DMR system (Board of Ed) or the new p25 System?getting it in Granby on DSDPlus. One affiliation so far on a single TGID
None of the sites are very high up but should be decent coverage.
chris
