Windsor
cg
Connecticut
Still testing, radio folks are there today.
FD had a call earlier, patch was up. I did see a console ID on a couple of the transmissions so did transmit on the TRS side of the patch.
EMS not patched today. I know EMS will have a conventional channel for mutual aid. Unknown if it will be a patch to the Dispatch talkgroup (250) or will simply be a standalone channel. It will be one of the current LTR channels.
chris
PhillyPhoto
Wethersfield, CT
DSD+ showing the last 4 hours of radios. It looks like PD has a lot of radios active on the system, not just "external" which would indicate a patch.
cg
Connecticut
Seems like more each day. The dispatcher is still UHF and the mobiles are as well (unless they are going only portables which I doubt). The FD tones appear to be going out on the P25 but the voice is almost inaudible at first then builds to normal after 5-8 seconds. It is still being worked on though so I would expect things to not yet be 100%
chris
cg
Connecticut
I would assume so, I haven't heard them in a bit either.
chris
scanner404
CT
Any chance anyone’s gonna be doing a live feed for Windsor If so I’m interested in listening to it
I might add it to the Granby feed in the future. Just moved to Windsor. Coming in clear for me.
cg
Connecticut
FD is still patched to 453.8000 still at least one UHF radio in service. I don't know if they replaced all the pagers with the Unication P25 units or not. If not, I would expect to hear the UHF for the long term.
EMS has a new one (453.6000 114.8)
PD is off UHF.
