Sitting by the boat launch for the past ~hour and haven't gotten anything except for calls from 65536
From what I've read, the 65xxx are patches for clmrn when radios lose connectivity to the towers.Have you made a guess as to what that 65536 TG is assigned to? EMS, PD or FD?
I'm trying to setup unitrunker v2 and see if it's any better but i can't get it. But I have my scanner running the system also.Ok on all. Thanks for the report. I’ll do the same after some programming...
Have you been able to continuously scan? I did it for about 6 hours today and only got that one tgid ScreenshotNo problem, happy to do it.
I had a feeling they weren’t using the new system yet. Not sure how they have interference, I didn’t hear anything on there system all day - but I don’t know systems. Do you have a source ?The following believed to be from Marcus Communication;
“Windsor is still on their old system, they are having trouble getting up and running on the new frequencys because of interference from West Springfield..”
So, it looks as if the thread is a tad bit premature. Still nice to know however. I appreciate the notification
No. But that doesn’t mean oneI recall an issue in my town (Farmington, Ct.). We were getting interference on our VHF High band repeater systems. Turns out our license was filed in such to use frequencies closer than accepted spacing allows. And when AMR Ambulance put up a transmitter in Worcester, Ma., on a too close to ours frequency, it caused interference. We lucked out because AMR was using a directional antenna and the repositioning of it was all that was necessary to drop the signal strength down below our normal noise floor.I had a feeling they weren’t using the new system yet. Not sure how they have interference, I didn’t hear anything on there system all day - but I don’t know systems. Do you have a source ?
No mention of system that may be interfering. I did not write the post, just passed it along. But the mention of West Springfield did not relate to the municipality of West Springfield. I read it to mean interference coming from a system in or near West Springfield. I looked at the municipality of W. Springfield and didn’t see any 700 MHz frequencies but I did not check other systems that may be commercial, or state and federal pools.P25 TRS not the DMR
TGID 911 & 912 logged with affiliation only.
65536 is CWID
Not sure what West Springfield would be using that would be interfering with 700MHz channels. They are UHF P25 now.
DId windsor start using the system yet?They're in the wiki here: Windsor (Project 25) Unknown Talkgroups - The RadioReference Wiki
They're more than like test radios to test voice quality.DId windsor start using the system yet?
I guess I'm assuming they are if someone has the uids
Have you done any real monitoring with a scanner and unitrunker? I'm not able to pick up the system from where I'm at.They're more than like test radios to test voice quality.
I saw they were online on my SDS100 when I was driving on I-91. I can just pick up the system from my house in DSD+. That's how I got the talkgroups.Have you done any real monitoring with a scanner and unitrunker? I'm not able to pick up the system from where I'm at.
