WISCOM (2010)
SB-Wi
Eastern Dane Co
ScanWI
MN & WI DB Admin
Wisconsin
I have been hearing talkgroup 9011 on the Columbus tower and Deerfield Tower. The talkgroup should be Federal and they sound like they doing surveillance. The Radio ID's list as Federal. I'm not sure the use of the talkgroup but I did here them mention DCI - Department of Criminal Investigation.
SB-Wi
Eastern Dane Co
Also heard traffic on Madison Trunking 42480 NGTF 2 and Dept. of Justice DCI conventional 153.775 in the area--they may have a patch setup for additional range or interagency coordination (can't receive digital so not sure)
ScanWI
MN & WI DB Admin
Wisconsin
well from what I heard they were traveling down 151 towards Beaver Dam and then they stopped somewhere I'm not sure were. They mentioned several times that Dane County was out with them too, I do have it all recorded.
Then they left and the last transmissions where in the the Madison area, mentioning location of driving on North Port Dr.
The talkgroup showed up on Fox Lake, Columbus, and Deerfield as they worked their way down 151
izz
Belgium, WI
Does anyone have any information on the status of the proposed Port Washington and Harrington Beach sites?
It looks like Port Washington won't be getting a WISCOM site.
From the Ozaukee County Radio System User Committee minutes, November, 8, 2012.
Ozaukee County is out of the running for a WISCOM radio tower due to lack of action on the project on the county's part.
Div106
Southeastern WI
Wow thanks to whoever provided all the WSP talkgroups! The question now is when are they going to be used more?
MarcusDude
Appleton, Wisconsin
Wisconsin DOJ/DCI should also be on WISCOM TG8301. I have heard TG 9011 used in Appleton, and in Milwaukee on the 800MHz site. I can't say for sure, but I suspect it might be the DEA.
kb8zxe
Wakefield, MI
I haven't been listening to WISCOM for quite a while now. Last night I decided to give a listen and see what was on the system. I used both my PRO-106 and Astro Saber to monitor. I was hearing traffic on talk group 134. Sounded like normal traffic stops and what not. However, the audio from the mobile unit sounded really bad. I thought it was just because the officer was in a bad spot. The audio never improved though and I heard dispatch asking the officer to repeat many of his transmissions throughout the night and this morning. I was monitoring the De Pere site near Green Bay. Dispatch's audio always sounded ok.
I haven't been following this thread so I hope I am not asking something that was already discussed. Any thoughts?
Bob
MarcusDude
Appleton, Wisconsin
The traffic on TG134 is not native WISCOM traffic. The reason the audio sounds so bad on is because it's a patch from WSP NER Fond Du Lac Post (154.935), and that frequency has the same hum on the end of the transmissions as is heard on TG134.
roofraft
lake county IL.
win 96 ext trunking tables
I have read many posts but I still need help listening to wiscom I dont think i am entering the extended table correctly any I live in lake co IL I pick up CCs towers 78% or more I dont know how to do the tables
JT-112
WISCOM is a lot different from STARCOM21, I'm not at all sure there's even any regular traffic where you are.
Hopefully it will pick up, but there's a whole lot of nothin' whenever I'm in Wisconsin (which is often).
I'm happy to be corrected, of course.
roofraft
lake county IL.
pro 96 tables
I do a lot of traveling in wis I hear some talk only on single channels when I set them to FM and I lock out the CCs if I knew how to do a screenshot of how I did my ext table I would post it not the sharpest tool in the shed if someone can post a screenshot of there table in win 96 maybe that would help thanks
JT-112
Never tried my Pro-96, but my PSR-500 never needed any extended tables to follow WISCOM perfectly.
JASII
Silent Key
WISCOM NAC Code(s)
I am a Minnesota listener "poaching" here on the Wisconsin side. Anyway, while driving south from Minneapolis today two frequencies popped up:
0139.0125 0139.0125 Off Off AUTO Off Off On Off Auto Digital B0D
0139.7375 0139.7375 Off Off AUTO Off Off On Off Auto Digital B0D
It looks like it is the Prescott WI site.
Anyway, my questions are:
-How many different NAC codes are in use system wide?
-What is the pattern for the NAC codes?
-Does each site have a different NAC code?
-I am assuming frequencies were selected in this area because a limited number of frequencies were available from 150.8 to 162. Also, I don't see them listed in the FCC, presumably because they are federal frequencies. Are all of the system frequencies known or are some still being sought?
-I heard NAC code B0D, but the listing shows something else. Is this possibly an issue of a different format of P25 NAC code?
-When I travel into Wisconsin, will the information in the Uniden Home Patrol be pretty accurate and up to date?
Prescott Site Details (Wisconsin Interoperable System for Communications (WISCOM))
http://interop.wi.gov/docview.asp?docid=19975&locid=166
4006
The system NAC is B0C. There are some sites that use a different NAC in their control channel stream to mitigate interference between sites that share the same control channel. When received on a scanner, it shows something like B0D but the systemwide NAC is still B0C.
JASII
Silent Key
WISCOM Thread (All Posts Regarding WISCOM Go Here)
I only see a couple of talkgroups for both neighboring Pierce and Saint Croix County, so I gather that the system is still being built out. Would it help any fellow listeners if I connected my Uniden Home Patrol HP-1 to my external antenna and tried to sleuth out some additional talkgroups? The traffic I heard sounded like a tone out for fire or EMS, so I suspect that they may be simulcasting on WISCOM and probably a VHF conventional frequency.
JT-112
So, what IS going on?
WISCOM "launched" last year, April 1 if I recall right. Perhaps that date was prescient...
I had expected at least some users to start populating the system in December in advance of the narrowbanding mandate - that hasn't happened on any sort of scale, as far as I can tell.
I also find it interesting that there are very few state users on this state system, namely the relative absence of the WSP. A few simulcast TGs for a couple of posts, that's it.
Someone got excited a few months back and added a slew of TGs to the database, but many of these appear to be notional only.
(Side note, it would be nice if TGs *confirmed* in use could be noted as such.)
If you go to the WISCOM website, you won't see any new documents, nor will you see any new calendar events.
All of this begs the question, what's going on here? While this wasn't a super-expensive system,* it's quite puzzling that it hasn't seen more use (yet). In Wisconsin, there has been some level of mistrust between the state and local authorities over the years, is this a factor here? Is there something fundamentally wrong with the system that's not been publicized?
Or, has the system always been designed to be slow-rolled? It hasn't seemed that way - like a lot of other people here, I listened to the techs hustle to have the system up and running.
This is interesting, to say the least. I've followed several state-wide systems as they launched and typically there was A) a major launch user, such as the state and B) pent-up demand and folks migrated ASAPractical. Not here.
Sixtytwo
* You really can't compare WISCOM to ARMER, STARCOM21, SAFE-T, MPSCS, DTRS, MARCs et al. It's a low-capacity system, not only in the number of talkpaths but also in overall capacity as it's VHF. Many of those other systems were also designed to encompass major metropolitan areas and to supplant current systems, not the case for WISCOM.
JASII
Silent Key
Monitoring WISCOM On Uniden Home Patrol HP-1
I am just wondering if anybody on this sub-forum is monitoring WISCOM on the Uniden Home Patrol HP-1? I am trying to monitor it now, but I haven't heard anything yet. I am located about 20 miles south of Saint Paul MN. The HP-1 shows:
Active Sites:
Baldwin
Dresser
Elmwood
Prescott
Also, I am connected to an external antenna and I am able to hear conventional channels just fine. For example 155.130 was just active moments ago.
JASII
Silent Key
I did just hear:
TGID 48010 Pierce County Sheriff's Office
Who, or how, do I contact the Wisconsin moderator to add this talkgroup to the database?
JT-112
Iowa to investigate adding 700/800 P25 statewide system
If this comes to pass, then here's how Wisconsin's bordering states will look:
Minnesota: 800 MHz
Iowa: 800 MHz
Michigan: 800 MHz
Indiana: 800 MHz (OK that's a stretch I know)
Illinois: 800 MHz
Wisconsin: VHF
Interesting.
