WV Interoperability System
mike_s104
Berkeley Co. WV/ Loudoun Co. VA
1501 - Fire/EMS Dispatch (Simulcast with Fire 1)
1507 - using for a fireworks event in Jefferson Co. today/tonight
1509 - heard more testing today
all RIDs are in the 150xxx and 151xxx range.
1507 and 1509 are on both the Jefferson and Berkeley sites. So far, the second Jefferson site is not live.
1535 - being used by Charles Town PD last night. this is the TG they started using over a year ago but then moved to TG 1529.
mike_s104
Hi wm8s,
Are telling me the scanner does not have to have Trunk capable to use Unitracker?
If that's the case, I have a older relistic scanner I can use.
Thank You
Eddie
I'm using an old PRO-2026 with a cheap antenna; works great. search the forums and the RR wiki for details on how to do. it required a little soldering, but not too much.
wvufan
West Virginia
More TGs on Logan site
TG RID
0001 (90002)
4207 (425150 425121)
9301 (99102)
9305 (99504)
9777 (97155)
9958 (90419)
insiderinfo
mike_s104
Originally Posted by insiderinfo View Post
I didn't know there was a second Jefferson site. Do you have more info on this and the frequencies/CC?
http://www.radioreference.com/apps/db/?sid=4076
The Kearneysville 2 site listed in the database is not a trunked frequency. The application says FB2. This isn't another trunked site in Jefferson. You should check your resources.
I was going off the RR DB. Maybe you should submit a change to the RR DB since you are apparently on top of everything. I'm not an admin of the RRR DB and I was not the one that submitted the info.
Looking back at your past posts, you seem to have more info that others do. Instead of telling people they are wrong, why don't you just give us the correct info and share with the RRDB and forum.
wm8s
Houston, TX
WSAZ had a lil story on the system today...
http://www.wsaz.com/news/headlines/23213994.html
Motorola xtl2500....
Interesting... the TG that traffic division is using is programmed as "Kanawha Tac-4" in my radio. I was about to change it to "CPD Traffic" (even though it's not in the Charleston TG series), when lo and behold it looks like Shawn's radio says "KC TAC 4" on the display. Guess I'll leave mine alone... ;^)
...R
blackacid
Bruceton Mills, WV
...R
Well I guess WSAZ was good for one thing....
Anywho I finally found a hotspot for my antenna so I can receive the Logan site now. I'm running unitracker through a motorola m120. Don't have a digi scanner yet so still outta luck on that front. Today is actually the first day that I have had a signal all day and there has been no activity cept the id. I did get 1 hit this morning but don't know what to make of it.....
wm8s
Houston, TX
I'm bettin it means that Kanawha County Medic 239 {radio 611322, I think) musta been somewhere near Logan and tried to affiliate with Kanawha EMS Dispatch but was denied cuz the TG isn't allowed down thar. Justa guess, tho...
...R
blackacid
Bruceton Mills, WV
Might as well put the radio to good use until I finish getting the antenna/coax to actually use it for my lil echolink project. Right now it's a pretty ghetto setup using an old cell antenna which is clip'd on to the back of the radio until I can get some mini uhf plugs in. It works for the time being.... Depending on how things go I may just dedicate it for a decode radio.
Anywhooo this is what I have so far.....
mike_s104
New TGs - Berkeley
TG: 1191
RIDs: 110192, 110172, 110180
Fire traffic, maybe training and a private channel.
TG: 1199
RID: 110001 (Berkeley Co. Dispatch)
IDed Fire Marshal Hale Channel.
TG: 1113
RID: 110723
No traffic recorded.
TG: 8003
RID: 80131
TG: 8001
RID: 80101
TG: 8011
RID: 80132
TG: 9055
RID: 95104
TG: 1921
RID: 151351
Recorded audio what sounded like testing on the Jefferson Co. site, but caught the RIDs off the Berkeley Co. site.
Also had a little bit of traffic on TG 1117, which I have as BCSO and Matinsburg PD, last night but I think it all was encrypted.
JESSERABBIT
Charles Town, Jefferson Co, WV
FWIW, Today while out and about, WVSP Charles Town on 42.06 sounded a bit weird. I think that they may be somehow simulcasting traffic off the trunked system. Wiill have more time tomorrow to investigate. BTW, thanks to all for posting information on this system. Every little bit helps. Also there was some troposheperic ducting taking place on 42.06 at about 6:30 pm today from the Missouri Highway Patrol. I don't believe that was the cause of the Charles Town "weirdness", but then who knows.
dintimid8or
New TGs Salem Tower
TG 9223
RID 98901
TG 9309
RID 99108
TG 3929
RID 330051
TG 3323
RID 331002
Best I can tell, the 3929 and 3323 should be in Region 4. All of these RIDs affiliated with Tower 105, Salem.
