XG-100P Intermittent Keypad
BMDaug
I am licensed…
Central Colorado, USA
NLT received all the remaining stock of parts that were left in L3HARRIS's service parts inventory for the XG-100P. The black front housings were never a released part. The same was true for the green housings. They only made around 20 something of each color before deciding not to continue production of them.
I thought they used the green housings for RF-900P variants…
-B
  • 33022417 3.pdf
BMDaug
I am licensed…
I don't believe any RF-900Ps were ever sold and beyond a few prototypes and spare housings, it doesn't exist. With that said I was lucky enough to get two green cases before they sold out.
Out of everyone here, I’m especially glad you got one!!!
-B
TDR-94
Well, it will have black side panels instead of gray and if it's like the green front housings, the top side button and PTT button will be black instead of yellow.
TDR-94
50 pound fingers break the membrane switches. Means replacing the whole front of the radio.
That would certainly speed up the process, but it's actually the the design. Even a brand new housing that hardly gets used will start becoming harder to push the buttons on. The keypads on these were just plain garbage.
DewAddict
SE, Michigan
Good info here, my keypad sometimes takes a few presses to register and I wasn't sure if it was an issue with the software or a keypad issue due to wear. Now I know.
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
Sometimes they will loosen up with use, it's less wear and more lack of use in a lot of cases.
jrothwell
Manchester, NH
Which flex? The keypad or side?
The side flex. It connects the accessory port to the board. It’s been several years since I took it apart to look at it. Looking at it now, I can’t tell or remember if the port is even part of the housing, I haven’t opened it up again since.
