arbitergvadam
San antonio
Hello,
I have a XG-100P that is stuck on the Harris XG-100 boot screen after powering the unit up.
I have attempted the trick of holding down the PTT and 2 menu buttons on the side only to no avail.
when reading the radio details in Radio personality maintenance utility most of the line items show up like the model number and the latest firmware. However the serial number sections shows "NONE" I am assuming this is where the issue resides. Its not a high profile radio so I have already written it off.
I was just curious if anyone has a recommendation aside from throwing it out the window to possible revive the radio.
Thanks in advance.
arbitergvadam
San antonio
I've (thankfully) never had one in that condition but does anyone know if you can read or write to the radio in boot screen mode? If so maybe load firmware and see what happens.
Cannot read or write to the radio unfortunately.
lbd1123
Was the radio connected to a system before it started doing this?
merlin
DN32su
Have't heard of one this bad off yet. This is not like the stuck in burnapp mode thing.
What you might try is blowing a new burnapp, then a new bootapp.
Find the packages with the *.bat files along with the *.exe files. (run the bat files.)
Doesn't matter what version, the idea here is to get RPM to load a recent firmware upgrade.
Now if the RS232 just won't read on the radio, then some catastrophic failure has occured
and the radio is a paperweight.
Here is a link to a recent burn/boot app
prcguy
There has been a number of radios on fleabay sold cheap as is with the boot screen and the sellers have not been able to make them work.
merlin
DN32su
Yea, but hese feebay flippers still ask prices so high, they think they will work.
I am in the market for such dud, but I think $100 is about all I would go. Don't expect to make it work, but make for an experimental platform.
How many of these sellers even have a programming cable. (As IS Unable to test further).
mikedaly
Redding,Ca
Hello,
Thanks in advance.
Mine did the same thing. You need to hold down the 2 softkeys under the display and the PTT then turn on. It will wipe the radio and load a default in.
TDR-94
He mentioned that he already tried that.
merlin
DN32su
If it were just stuck in burnapp, there ia a front key sequence to get it back to normal.
RRR
OFFLINE
USA
What does the XG-100P do when inhibited?
nikronzo
XG100P doesnt have burnapp, it has unified bootloader sequence, if its stuck it will be on general XGP code update
It makes a nice door stop, which is only slightly worse than a non inhibited 100P since its already a piece of garbage
prcguy
It still does just about everything an APX8000 does for 1/8 the price. Programming one is a breath of fresh air compared to APX.
TDR-94
I think he might have misspoke. Since there is no "trick" involving holding down the 2 lower side buttons and those buttons aren't usually associated with the radio menu.
addredhead17
Mission viejo CA
Do u know of any other links from mega for the u know what? I had so many mission plans on mine, and it got stuck on the front boot and wouldn't load? I did the three finger salute, and I lost everything , the computer I had used to program it finally crashed and now I have nothing do you know where I can get something , sad ham 😢 thanks
addredhead17
Mission viejo CA
adamr368
NJ
A lot of these keypads have issues, so it's possible that the buttons aren't making contact even if you're pressing the correct ones. Due to the intermittent nature of the older keypads, you may have to try numerous times to get good contact or press fairly hard.
