K2NEC
NA
Hello! I am trying to get my XPR6550 and my TYT MD-380 to work together when I press the man down button. I have the "emergency decode" fields checked and my issue is that my XPR WILL decode the man down on my designated emergency channel, however, my MD-380 WILL NOT decode the packet but does receive a signal. Is there a specific field or adjustment that I have missed? Any help is greatly appreciated!
rescue674aa
I’m an idiot
Two different radios..same with the private settings
rescue674aa
I’m an idiot
Not really Acks can be different
MSS-Dave
Generally Central Florida
Is there any way to fix it?
This is going to sound harsh but it's an MD 380, not a Motorola. If the Motorola decodes from whatever system you have and your 380 doesn't, I'm going with it's not compatible. Motorola tends to do things slightly off of DMR standards to be proprietary though.
I'm really hoping that this is something you're experimenting with and not an actual usage of a MD380 on some sort of an important system.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
K2NEC
NA
The use of a $100 radio on any important system is just foolish ;)
But I am just testing the two radio's on DMR simplex frequencies and found the emergency function so I thought it would be cool to implement. It was one of those "for laughs and giggles" kind of things. I appreciate the help! :)
RadioGuy7268
PA
Check that the XPR6550 is set for messaging as "DMR standard" - rather than MSI or "proprietary". There's also some settings for "data confirmed" - but I'm not looking at a codeplug right now to tell you. I'm also thinking that there were some firmware updates along the way that fixed some of the DMR standard compatibility issues with the 1st generation MotoTrbo units.
The MD380 is impressive as hell for being a first generation unit. Once they get some of the bugs worked out & fix a little of the massive desense, it's going to be hard to justify spending 4 or 5 times more for a "branded" unit that has fewer features.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
The MD380 is impressive as hell for being a first generation unit... it's going to be hard to justify spending 4 or 5 times more for a "branded" unit that has fewer features.
The lack of customer support, and the lack of warranty service make NOT buying a TYT an easy choice.
At least with CSI you have a North American point of contact, who stands behind the products he sells.
kayn1n32008
Sector 001
Rule #1 Never mix radios on a system.
Rule #2 Only mix radios on a system if you are only talking and not using SPECIAL FEATURES.
Rule #3 If you have to call China for warranty support, don’t waste your time.
buddrousa
Good Rule. I have 2 380 UHF and 2 380 VHF they all 4 are like toys I have not ever used my 380's for FIRE DEPARTMENT use for that I use EF Johnson 51SL 800, Kenwood TK2180 soon to be replaced by a NX5200, and also my Kenwood NX5300.
IAmSixNine
Dallas, TX
We talk about Scanner Club instead. Now thats an open forum. LOL If you show up to scanner club with a scanner and radio then you can join radio club with out talking about it. But make sure the radio has proper programming or risk it turning into fight club.
Hold on the head pumba is calling me. I have to give the secret hand shake so cant type any more.
