XTL/XTS5000 XTS 5000 scan list programing
Radios_With_Jackson
ÆS Ø
Richmond, VA
Hello, I am attempting to program a scan list directly on my XTL 5000 and It will not let me remove or add channels. and the scan list program softkey will not show on the display. I have been using the ABC switch to put it in program mode.
Skypilot007
Medford, NJ
If memory serves correct, you need to change the function of the ABC switch to something else or unprogrammed then program the soft key and it will show up on the display. Can't have the ABC switch and a soft key programmed for the same function. Softkey loses, ABC switch wins. There is also a setting to enable/disable scanlist programming via menu or softkey/ABC switch. I can't remember where in CPS that is.
Baker845
anywhere
If you click on Radio configuration, it will bring down options, for switches and buttons and, you can program scan list prgm option.
MatRat80109
Colorado
I set the Menu item of View and the toggle switch B to Scan List Prgm to allow the viewing and editing of scan lists. We use the concentric switch to turn scan on and off. The Scan List will need to be set to Operator Select and the Scan List has to be set in each personality that is associated with channels you want to scan from.
If I recall correctly, the scan functions will not work (or appear in the menu) if you have a channel selected who's associated personality does not have a scan list selected.
Good Luck,
MR
Baker845
anywhere
correct, if you don't have the personality selected for scan you won't be able to change the scan lists.
