XTS2500 Analog Rx & Tx
hill
Middle River, MD
Perhaps the OP could clarify what this frequency is used for
I guess he could but he also said which other frequencies he could use. So we really don't know how is going to use the radio. Looks like he is just trying to use them between his radios and not for official reason.
Ah, must be why. Do you have any frequencies tha5 are approved for the XPR? Thanks.
kf8yk
Many agencies, can/do use the Outputs for some Simplex ops, altho some never listed on the FCC licenses :( which should be MO's
Additionally the License quoted only lists Repeaters (FB2) and not even the inputs. WPLU697 lists the inputs
I'll point out that FCC rule 90.621(a)(1)(ii) allows 800 MHz licensees to operate simplex on any repeater output without the need for licensing additional MO's.
hill
Middle River, MD
The op is over 100 miles from the system listed and was the only listing in MD
Not used by the trunked system in Howard County, but they still hold a license under WPQX905 for 860.7375 and most likely used for simplex operation like the database on this site shows.
Please see the links below.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
The XPR was not approved on some 800mhz frequencies. Ran into this with the 8TAC stuff as custoemr bought one and couldn't use it. Verify radio split.
No. Motorola blocked the NPSAPC specific frequencies, to force public safety agencies to the ASTRO series. The XPR7x80/5x80series radios cover 806-941MHz. This is why you need the 'Canadian' EID to unlock those specific frequencies.
Async
The Infamous /\/\
Howard County, Maryland
To let you all know, yes I have permission to use this. But the radios are suddenly talking to each other, but when I'm on a different zone. I'm guessing it's a scna issue which I can easily fix. Guess it went under my radar. Thanks to all!
Async
The Infamous /\/\
I have three (3) radios that I seem to not be able to talk to each other on analog simplex.
Radios: XTS2500, XPR7580e, XPR7380e
Frequency range: 850-860 MHZ
Everything matches.
All DPLs match up and the Signaling Systems are all turned off.
The XPR7580e and XTS would talk to each other but suddenly stopped after I experimented with some stuff, but reverted it.
Am I missing a step?
Update: all working.
Async
The Infamous /\/\
Now now now...let's not use that nasty word NO. That's a bad word here on these forums. I am sure the O/P is the authorized licensee, has all formal training and knowledge to program part 90 public safety radio subscribers, and is just checking out their local hobbyist forum to make sure they didn't overlook something obvious.
Exactly this. Thanks!
