XXTS2500 Software option question
N1SQB
Somewhere On Earth
Considering an XTS2500 in the 403-470 range. I want to use it, among other things, to monitor P25 digital frequencies NON trunking. One thing I do not understand is the difference between software options Q 811-P25 digital conventional and Q 806 Astro IMBE digital operation. Can someone explain the difference? Everything else about the radio I understand.
Manny
GTR8000
NY/NJ Database Guy
BEE00
Q811 only gives you digital conventional (i.e. Digital Voice), but Q806 will get you P25 trunking as well.
That is not correct.
Q811 was the original FLASHcode option for P25 DIGITAL CONVENTIONAL. It was later replaced with Q806 DIGITAL CONVENTIONAL (P25), which is paired with H35 in portables or G48 in mobiles for conventional operation.
Neither Q811 nor Q806 "gets you P25 trunking as well". Additional features are required for 9600 trunking.
N1SQB
Somewhere On Earth
Thank you for clearing that up for me.
Manny
akardam
Q811 might show up in the CPS feature display, but it was never a true flashcode option. It was an order option that would generate Q806 and H35 in the flashcode of, for example, a XTS2500.
"Lower" tier radios like the XTS2500/XTS1500/PR1500/MT1500, had the concept of "system packages", that you had to chose from in the catalog, with several flashcode options bundled in (and then in some cases add on other/misc options as you liked).
With "high" tier radios like the XTS5000, you could pick and choose basically a-la-carte (but of course you had to meet all the pre-reqs and deps).
Here are some screenshots from the old price pages, showing an example of the differences:
XTS5000:
XTS2500:
