Yaesu FTM-400XDR Install - 2019 F150
K3VDM
Chester County, Pennsylvania
Installed a Yaesu FTM-400XDR in my 2019 Ford F150 a few weeks ago. I used a solenoid which is tied to an ignition fuse in the truck. The fuse block powers on and off with the truck. The antenna is a Diamond NR770HBNMO mounted on the front driver fender. The dash mount and behind rear seat mount are both Builtright Industries products.
Screen Shot 2022-02-08 at 1.04.32 PM.png Screen Shot 2022-02-08 at 1.05.45 PM.png
Control Panel Mounted on a Builtright Industries Dash Mount
Radio, Fuse Block, and Solenoid Mounted on a Builtright Industries Panel
Microphone and Yaesu MLS-200-M10
Let me know your thoughts!
-K3VDM
captainmax1
Florida Keys
Nice setup but a radio mounted up on the dash where I live would fry from heat very quickly. Is extreme dash heat a problem where you live?
prcguy
A friend had a late model Ford pickup and was able to fit the FTM-400 control head in a flip down compartment in the overhead console thing. It barely fit but looked factory stock when it was done.
AK9R
Central Indiana
Not really. I am in Pennsylvania. During the summer months, I plan on putting a small towel over the control head to keep the sun off of it.
I have run a Kenwood TM-V71 control head mounted to the top of my dash in a Ford Expedition for years. I live in central Indiana. No issues.
W9WSS
Retired LEO
Westmont, DuPage County, IL USA
Very nice install, however, you may wish to deploy some flexible plastic looming to dress up the rear compartment a bit. But as long as it does what you want it to do, the rest is just cosmetic.
K3VDM
Yeah that's the plan. I had to take that back panel out because I brought the truck to Ford to fix a leak in the rear window. While it is out I am doing some cable management.
pointman1177
Metro Detroit, Mi
curious what your antenna setup is like. love the install, exactly what I would do. I need more ideas for the new truck I ordered. Thanks!
SurgePGH
Belle Vernon, PA
If i'm not mistaken that radio won't do well being powered of through a power interupt. It needs powered off with the power button or you run the risk of corrupting the SD card.
03msc
RF is RF
The Natural State
Isn't the card only used for programming? And that's done manually (i.e. telling it to read from or write to the card; it doesn't happen automatically). So, if that's the case, it shouldn't be accessing the card except during those periods. I'm not recalling a recording function but that would be a more likely reason for a potential corruption of the card.
vagrant
ker-muhj-uhn
California
No, it is required for the GPS to log and some other things which I forget at the moment. My radios have constant power and I use the APO ( Automatic Power Off ) feature after a set time.
jeepsandradios
East of the Mississippi
My FTM400 has been run off a relay for 2 years in my JT with no issues. Turns on with key and off when I shut off key. APRS works fine. APO was used first but on tris it would shut off without me knowing. My card has all my programming on it in case I want to pull it back or program inside on my desktop.
Solidjake
NYC
I love the black metal plates you have everything mounted to, NICE!
chief21
Western NC (Summer); Tampa Bay FL (Winter)
I've been running the FTM-400 rigs in my two vehicles off an ignition relay for years with NO issues. Very convenient.
