caravanken
I am getting much lower audio from the Ext Spk connection on the back than I am Headphones. I feed both into a Behringer Xenix Q1202 mixer and the Ext Spk audio is much lower. The audio from the Headphones has a popping when the scanner turns on audio for a freq and pops again when it turns off. My 996 and 436 do not have this popping. The internal speaker audio is fine (clear and comparable to my 436 or 996).
I could not find in the manual whether to use a TS or TRS. Does it matter?
From the manual: Audio Output Power: Internal Speaker - 360mW nominal (24ohm)
Headphone (L-ch) 4mW nominal (32 ohm)
From the manual: BCD536HP Only - All audio output is Class-D amplified (PWM). Never connect Ext.
the SP Jack or Headphone Jack to an external Class-D AMP.
I have my BCD436 and BCD996XT both going to the mixer and has for a long time with great results. Would anything about this scanner preclude the use of a Behringer Xenix Q1202 mixer?
Does the scanner need to go to the shop?
Ken
Ken
