Did some more testing today.
I removed the zener diode, as well as the DC noise filter and left just the two capacitors and the diode to prevent backflow, power coming from my ignition triggered relay. I stuck the probes of my multimeter into the power connector for the scanner. Since the CB is on the same power line, I used that as my load.
- No load (CB turned off) - straight 14V, no fluctuation
- With load (CB turned on) sitting in Park, 12-12.2V
- With load driving, foot on gas - eventually leveled out to 13-13.2V
- With load driving, coasting - eventually leveled out to 13.5-13.6V
- With Load, stopped at a stop light, anti-idle engaged and engine off - drops down to 11.2V
- With Load, stopped at a stop light, anti-idle engaged and engine off, take foot of brake to restart engine - This was all over the place. Sometimes it would dip as low as 10.2 or 10.5V. Other times it would stay above 11.2/11.3V and immediately rise back up to 13V+
I'm going to find some time later this week to swap out the capacitors. For the 1 farad, would hooking it up to the positive and negative terminals of my fuse/junction block be OK even though that means the cap would power the other equipment as well?
I'm thinking I'm going to purchase the DC-DC converter. I found it on ebay for $28 shipped from NJ. If anybody knows of a similar unit on Amazon that has Prime shipping, that would be preferred and appreciated. I couldn't find the same model on Amazon.
