Alachua/ Gainesville GRUCom P25 (4D9.BEE00)
KO4IPV
IN Florida database>System Name= Gainesville Alachua < there is a special note about banding what is this ? and it would be Alachua county. I have made a new favorites list from this county with the SDS100 ,not hearing anything??????
batdude
Florida Db Admin / Florida Forum Moderator
Moderator
East Central, Florida
i believe the system you programmed has been decommissioned >>>> Gainesville / Alachua County Trunking System, Gainesville, Florida - Scanner Frequencies
the replacement / new system is here >> Alachua County - Gainesville Regional Utilities (GRUCom Project 25) System Trunking System, Gainesville, Florida - Scanner Frequencies
let me know if that helps!
if you can confirm that the old system is indeed no longer on the air - please submit to have it removed via the "SUBMIT" button!
thanks!
doug
Whiskey3JMC
Google-Foo Ninja 4 Hire
Simulcastylvania, TE
No custom band plans should need to be created on an SDS100. The note clearly states models affected. Per the post above, they migrated to a new system
KO4IPV
i believe the system you programmed has been decommissioned >>>> ttps://www.radioreference.com/apps/db/?sid=195
thanks!
doug
thank you that explains it
SRSP2282
Alachua County, FL
This system is no longer in use. Traffic has been migrated to the P25 system. Ill submit a request to have it removed.
To answer your question.
That is a note from many years ago when the 800mhz spectrum was reorganized by the FCC when cell companies migrated to other parts of spectrum. (There is a way more complex version of this answer if you want to do a deep dive Rebanding - The RadioReference Wiki)
KO4IPV
how long does this take to revise that system after you report ?
KO4IPV
Thankyou for your expertise in this matter really appreciate it , there is not much to listen to in my area fixing that really made my day.
Can you please help me here ? After the update is made do I need to update the master database in Sentinel software first before making new favorites list for Gainesville/ Alachua county ?
KO4IPV
working with the SDS100/ programmed Gainesville /Alachua P25 Upgraded system I dont here any thing are there any special settings my scanner should be on ? NAC setting ? Perhaps ? or The Decimal-Hex Setting something I am not doing or doing incorrect . I am 25 miles South of Ocala I receive Putnam county just fine all conventional.
trooper890
N/A
You're probably approaching 50 miles to the nearest GRUCOM site, there's no way on a handheld. Running an outside antenna? If not, I don't think you'll get reliable 800mhz signal at that distance. Even with one that's a tall order. VHF is a breeze compared to 800 simulcast.
KO4IPV
Ok i’ve been very confused because I get Puttman County which is same distance but all conventional comes in loud and clear and when I program Gainesville which is just west of Putman.P25 phase ll I hear absolutely nothing and I know my scanner works with that type of simulcast because I’ve traveled and I could receive it just fine and I do have an outside antenna I pick up the signal but no voice
whooey
Gainesville, FL
Once I get out of the county going south, signal fades quick, unless u have a tall antenna outside, doubt you will pick up alachua county.
KO4IPV
Thanks that explains the problem I do have an outside antenna but it’s only roof high and I am quite a ways from Gainesville just figured I could pick up Alachua county since I do receive Putnam county, But I was told that P 25 is harder to receive the signal then conventional as far as distance goes
Gatorman
I see the Phase II system has been updated. Can anyone, who is listening, I'm not there at this point, tell me if the system is still able to me monitored? I recall some discussion about encryption earlier.
Thanks much.
batdude
Moderator
This system is a real stretch for me to hear - but there seems to be lots to figure out.... just my short listening opportunities, i have found four TGs that are Un-IDs.... 3091, 3097, 3107 and 4011.... I do not think the "whole system" is ENC....
doug
KO4IPV
doug
Don’t see anything listed as E
ke4crc
Lakeland, Fla.
Back in 2015 time frame, I used to visit Alachua county and back then they were p-25 BUT I had to program my scanner as MOT analog TRS
I assume that's changed by now ?
I travel to Ocala once a week but never hear any traffic on Marion county
