Anyone in the Dothan or Enterprise Alabama using SDS100 to listen to NXDN?
DudleyG
Lexington, Ky
The LCN is shown in the Sentinel Database from where you did the add to favorites, you will just have to write the numbers on a piece of paper and then enter them in your favorite, no easy way to do a copy and paste.
If this works, you will still hear the Enterprise Police on the STREETS frequency but should also hear them on the City Of Enterprise Trunk System. If that a problem hearing in two places, that is easy to fix.
Since the LCN in the database have 0 for LCN in the Enterprise (PD) entry, I would use the same LCN that are in the City Of Enterprise uses which are 91 to 95
jjl0412
Daleville, AL
Ok.. will update LCN 91-95 for Eprise pd in S & P.. Let you know if it helps..otherwise..I need to listen a while and get back to ya..but as of now EMS,1 time, is the only responder to Streets dispactch..which i have heard now 6 or 7 times since reload..
DudleyG
Lexington, Ky
Now that you wrote the new info to the scanner, when it is scanning, do you see the the City Of Enterprise scroll across the screen? I wondering if the police have actually moved to the new truck system or everything is setup so they can move sometime.
jjl0412
Daleville, AL
Also, to be clear, I don't have to worry about Quick Keys or any other changes at this point, right? Once I update LCN and reload, I will listen a while and let you know if our changes are good..E'prise EMS and Streets dispatch are L&C..5x5. And Thank you so much for your valuable time.. I'm finally confident we will get this sorted.. I wilol get backto you this evening and let you know what i hear..
DudleyG
Lexington, Ky
Quick keys just make it easy to turn on and off systems, sites, etc, but now the scanner will just scan everything
jjl0412
Daleville, AL
done
jjl0412
Daleville, AL
Yes. I see it. Eprise Fire EMS have responded, though i did not hear Streets call them every time.. put police? Ok it showed Fire Dispatch, then Streets said PD is route..but never heard any pd traffic. Ok I hear other traffic on Streets too but no idea who.
DudleyG
Lexington, Ky
If the scanner stop on a frequency that has City Of Enterprise on the screen near the middle, that means it is on the trunk system at that time. You should be able push the soft key associated with Channel and hold there. If it stops on Police or EMS and City of Enterprise is not somewhere on the screen, then it is pickup the traffic from the conventional systems. To get of the hold, just push the soft key again.
jjl0412
Daleville, AL
[/QUOTE
ok, Thanks.
jjl0412
Daleville, AL
FYI after 30 minutes so far..Fire and EMS respond on streets and their name shows up.. No PD traffic so far...
DudleyG
Lexington, Ky
The next time the scanner stops on traffic, can you push the soft key for Channel (the right most soft key) hold and take a picture of the scanner screen with your cellphone and post it. It would helpful if you get a picture for fire and another picture for EMS.
4dot2
Ozark,Alabama
154.445000,"ENTERPRISE, CITY OF 100FB2 YW",NXDN
155.625000,"ENTERPRISE, CITY OF 50FB2 YW",NXDN
155.700000,"ENTERPRISE, CITY OF 50FB2 YW",NXDN
156.195000,"ENTERPRISE, CITY OF 100FB2 YW",NXDN
154.370000,"ENTERPRISE, CITY OF 100FB8 YW",NXDN
153.770000,"ENTERPRISE, CITY OF 50MO YW",NXDN
154.370000,"ENTERPRISE, CITY OF 50MO YW",NXDN
154.445000,"ENTERPRISE, CITY OF 50MO YW",NXDN
155.625000,"ENTERPRISE, CITY OF 50MO YW",NXDN
155.700000,"ENTERPRISE, CITY OF 50MO YW",NXDN
156.195000,"ENTERPRISE, CITY OF 50MO YW",NXDN
158.970000,"ENTERPRISE, CITY OF 50MO YW",NXDN
159.052500,"ENTERPRISE, CITY OF 50MO YW",NXDN
159.075000,"ENTERPRISE, CITY OF 50MO YW",NXDN
159.120000,"ENTERPRISE, CITY OF 50MO YW",NXDN
4dot2
Ozark,Alabama
769.831250,"Ozark, City of 70FB2 SY",AUTO
771.231250,"Ozark, City of 70FB2 SY",AUTO
772.131250,"Ozark, City of 70FB2 SY",AUTO
772.581250,"Ozark, City of 70FB2 SY",AUTO
772.956250,"Ozark, City of 70FB2 SY",AUTO
774.156250,"Ozark, City of 70FB2 SY",AUTO
774.881250,"Ozark, City of 70FB2 SY",AUTO
769.831250,"Ozark, City of 30MO SY",AUTO
771.231250,"Ozark, City of 30MO SY",AUTO
772.131250,"Ozark, City of 30MO SY",AUTO
772.581250,"Ozark, City of 30MO SY",AUTO
772.956250,"Ozark, City of 30MO SY",AUTO
774.156250,"Ozark, City of 30MO SY",AUTO
774.881250,"Ozark, City of 30MO SY",AUTO
799.831250,"Ozark, City of 30MO SY",AUTO
801.231250,"Ozark, City of 30MO SY",AUTO
802.131250,"Ozark, City of 30MO SY",AUTO
802.581250,"Ozark, City of 30MO SY",AUTO
802.956250,"Ozark, City of 30MO SY",AUTO
804.156250,"Ozark, City of 30MO SY",AUTO
804.881250,"Ozark, City of 30MO SY",AUTO
4dot2
Ozark,Alabama
770.306250,"DALE, COUNTY OF 100FB2 SY",AUTO
771.531250,"DALE, COUNTY OF 100FB2 SY",AUTO
774.456250,"DALE, COUNTY OF 100FB2 SY",AUTO
799.356250,"DALE, COUNTY OF 15FX1 SY",AUTO
jjl0412
Daleville, AL
jjl0412
Daleville, AL
Thank you. Your advice on what do with this information would be appreciated.
jjl0412
Daleville, AL
And as of now, 5+hrs later after we reloaded the 436, no police traffic I can see. Sometimes there will be a different voice on the Street, as though 2 people are taking using the same freq.
DudleyG
Lexington, Ky
I am happy with what the pictures on your scanner screen are showing. The Elba Fire Dispatch is coming over the S&P Trunk System showing RAN:9 and TGID:4010 which matches the Sentinel database. The City of Enterprise EMS Dispatch is coming over the City of Enterprise Trunk System showing RAN:9 and TGID:2500 which also matches the database plus Enterprise Fire Dispatch is also coming of the C of E Trunk System and showing RAN:9 and TGID:2421 which matches.
Looks like to me both NXDN Trunk System are working. Changing the City of E Trunk frequencies to RAN:9 seems to fix that.
Question: in the first picture, it is showing the Streets conventional, one frequency of 156.1950Mhz but that same frequency is also part of the other 2 Trunk Systems. Do you remember what agency was talking (Fire, EMS, Police). I am not at least surprise that frequency is getting hits since it is part of the 5 frequencies in the trunk systems.
The real surprise is: if you aren't hearing the Enterprise Police, what changed.
DudleyG
Lexington, Ky
Please check your information in Sentinel favorites that you wrote to the scanner and make sure that the conventional STREETS entry still shows a Service Type of "Law Dispatch" and didn't get switched back to "Public Works".
From the above comment about hearing 2 people talking on the 156.1950Mhz frequency - that is very likely and maybe the two aren't even talking to each other, they may be from different agencies. The whole concept of Truck System is to share frequencies amongst different agencies versus each agency having its own frequency. What separates the different agencies on a Trunk system is the TGID which for example all Enterprise Fire units should have TGID:2421 so they only hear each other.
