bc796d scanner question?
bluefox2163
does anyone know if the bc796D scanner can be updated for a rebanded trunked system? and how is it done?
captclint
Mentor
Mountaintop, PA
According to it's spec's Yes. Need to wait until the availability and method to update is announced here or here: BC796D : Uniden Bearcat BC796D email list It was originally estimated the end of this month, but I suspect that has slipped.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Last I heard, it will be in mid-Feb.
If it follows the other Unidens, you will get a series of values to enter into a table. How that table will be accessed I haven't a clue, but at least you will not have to send it somewhere. I would expect that, eventually, the popular software packages will catch up.
73 Mike
mike6454
Eagan,MN
RE;BC796 Rebanding
My 796 just simply loaded the systems and TGID's
Once the rebanding was updated on the RR database
Good luck
UPMan
In Memoriam
Arlington, TX
Mike:
Seems you were fortunate to be scanning either an EDACS, LTR, P25, system or a Motorola system that did not require any of the new rebanding channels (that would have resulted in your scanner needing a custom band plan to determine the correct voice channel frequencies).
Most Motorola systems that reband will require a custom band plan.
