Yeah, display mode 3 is useless now. It has ONE blinking indicator (I assume for the CC) and it never changes. (I have ALL the trunk frequencies for this system programmed just for the purpose of using display mode 3.) Maybe this is just a bug of the new firmware?
I hardly ever use this display mode so I won't miss it too much. It seems like a waste to have it as one of the official three display modes of the scanner... if it isn't just a new bug that is.
Trouble with the update. This is the same problem I had with the last update to
my BCD396T. I dropped back to BC_VUP v2.0.0.3 and everything worked perfectly.
BTW: I'm using a Vista PC.
What are you using for the serial connection? Uniden USB-1 cable, serial/USB adapter? What COM port is it using?
i updated mine and for some reason one of my systems would not work anymore i checked everything nothing was locked out it was one of my systems that was an 800mhz type 2 motorola trunked system and it worked before i did this update i can hear the control towers noise and all and if i hold onto one of the control channels i could see the talkgroup ids coming up but could not pick up any talkgroup ids at all while scanning the system and from what i can remember with my 396 t this happened to that also with some updates before the same exact problem with certain systems i was just wondering if anyone else had this issue i had to reprogram the system and now it works fine anyone ?
