BCD536HP Mobile, Wifi, and More
TheBCD536HP is Uniden's new flagship mobile scanner...which incorporates two firsts. Like the BCD436HP, it is the first standard mobile scanner to include the ease of use of the HomePatrol-style database; simply enter your zip code and away you go. But, the BCD536HP adds to that WiFi connectivity, allowing you to listen to and control your scanner using your smartphone or tablet...from anywhere in your home, vehicle, or around the world.
4 Gigabyte microSD card holds the entire USA and Canada database of radio systems, plus leaves room for hundreds of hours of audio recording.
Programmable Alert LED lets you set a specific color to alert you when a channel becomes active.
TrunkTracker V with support for APCO Project 25 Phase I and Phase II, X2-TDMA, Motorola, EDACS, and LTR Trunked Radio Systems
Quick Key access to 100 Favorites Lists, 100 Systems per Favorites List, and 100 Departments per System.
Discovery Modes help you find new channels on trunked systems and frequency ranges.
Analysis Modes include Band Scope, RF Power Plot, Trunked System Analysis, and EDACS/LTR LCN Finder.
Flexible Easy Channel Selection using Zip Code or GPS and Service Types — just pick the kinds of channels you want to hear and tell the BCD536HP where you are and let it do the rest.
Easy Scan Control using the dedicated System, Department and Channel Hold buttons.
Complete Front-Panel Programmability — create custom Favorites Lists either using systems from the main database as a starting point or program your systems from scratch.
Temporary Avoid lets you quickly silence unwanted systems, departments, or channels while allowing you to restore them by cycling power.
Backlight-on-Squelch option allows the backlight to remain on during an entire transmission.
Date/Time indication on display with time stamping for recordings.
Trunked and Conventional Channel Priority with Priority Do-Not-Disturb
Close Call® RF Capture with Do-Not-Disturb automatically tunes the scanner to nearby transmissions without interrupting reception in progress.
NOAA Weather Alert with SAME
Two-Tone Paging with up to 32 tone slots
Flexible Scanning — scan from any combination of the main database and Favorites Lists
Included Sentinel Software makes database and firmware updates simple. Also allows you to create, edit, and manage your Favorites Lists.
USB PC Connectivity
Serial GPS input for location-based scanning useing the Uniden GC-GPSK or other compatible GPS receiver.
64 x 288-Pixel Dot-Matrix Display
Backlit Display and Keypad
Printed manual in the box with online updates.
Available January, 2014
Uniden New Scanners Info Site
Uniden BCD536HP Spec Sheet in Adobe Acrobat PDF format.
Uniden BCD436HP & BCD536HP Owners manual in Adobe Acrobat PDF format
Sentinel software program companion to the BCD436HP/BCD536HP.
