Broadcastify Raspberry Pi Image v3.0 Beta
boonebroadcaster
NKY
Progress Report- Identified power supply was the issue. I was able to boot into the image, report into the desktop, and upon clicking on the SDRTrunk received an error, same with the Broadcastify Shell (file/directory not found). Now, this could have been a user error, as I changed the username and password and hostname prior to writing image to SD card. Starting back over, thinking that might have had something to do with it.
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
Yup, that's going to be your problem.
You can change the hostname and password for the user pi, but if you change the username I really can't support you going forward.
It's an appliance. Boot it up and follow the instructions. If you want to get cute with the configuration out of the gate, well...
boonebroadcaster
NKY
Got her cooking, ended up having the most issues identifying a power supply issue. Once I figured out the hostname using some nmap prompts, I was able to get it set up appropriately. Copied over my SDRTrunk playlist from the Pi 4 and we are back in business. Great build @blantonl and appreciate all of the support!
boonebroadcaster
NKY
Open Raspberry Pi Configuration and it will list the hostname there.
I was running it headless, trying to SSH into it. Finally broke down, located a micro hdmi cable and was able to getting it running. Was trying to avoid having to connect it to a display, as I didn't think I had a micro hdmi cable. Got lucky and found an adapter in the junk drawer!
scottb908
Terryville CT
Loaded the image onto an older Pi3. I'm not sure what is dragging on the machines; however, even the basic functions are painfully slow, like opening a browser. I get its an older hardware so I accept that. I attempted to use SDRTrunk with a single RTL, and both times, after about 45 minutes, the app locked up. Terminal and other services were still running so it wasn't an entire OS lockup. Going to see if I can find an older version of the image and see if it performs the same way.
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
There is absolutely no way SDRTrunk is going to run on a Pi3. It barely runs on a 4.
Anything below a Pi4 should be used only to provide a single feed via darkice or run RTL-Airband.
Kingscup
Are we required to upgrade, and if not, what would be a big reason to upgrade if I'm using this on a RPi4 with 2 SDR dongles? Any great new features or fixes?
‘If you use trunk recorder, the new version massively reduces system resources which can allow you to add more talkgroups/recorders/frequencies if needed.
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
Yes, trunk-recorder v.5.0 is included and has significant performance enhancements. you should be able to monitor a large trunked system site from a Pi4, or multiple sites from a Pi5.
csteinman
Rio Rancho, NM
I have a 2.7 GHz Dell Inspiron laptop running SDRTrunk and Trunk Recorder with Windows 10 and 12GB RAM. Running 2 RTL-SDRs to monitor one P25 trunked system. I am experiencing quite a few garbled transmissions. Would I be better off with the Raspberry Pi 5? I would like to get my laptop back, but only if I could see an improvement in decoding audio.
Thanks.
csteinman
Rio Rancho, NM
It's 12 miles LOS and RSLs vary, as reported by SDRTrunk, from -50 to -29. I'm thinking it may be a decode issue. But that's probably a topic for another thread.
What I am looking for is, does the Pi5 have sufficient horsepower to do everything it needs to do to support SDRTrunk running P25 trunked, simulcast, Trunking Recorder, and possibly ProScan all at once. If that is just on the edge of it's capabilities, I'm probably best off with my laptop. If it can do what it says with room to spare, I'll buy one.
I'm seeing comparisons with the Pi4, but since I am not familiar with that either, and I'm not a computer nerd, I don't have enough information to know if the Pi5 is really that good, or just good enough to get by. The price point is suspicious, but then it only has to do one thing, whereas a windows computer is more expensive, but has to do a lot more.
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
You can't run ProScan or TrunkING Recorder on a Raspberry Pi. It's not a Windows Machine.
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
Don't do that. The instructions at Broadcastify Raspberry Pi Feed Appliance Image are as follows:
Steps to Flash Image to SD Card using balenaEtcher:
  1. Insert or attach a blank SD Card to your computer
  2. Run balenaEtcher
  3. Download the image to a location on your hard drive:
    Download
  4. Choose "Flash from File" and choose the downloaded image on your hard drive.
  5. Select your SD card as the target
  6. Click Flash!
  7. When the flash has completed, insert the SD card into your Raspberry Pi, Power On, and follow the configuration sections below. When you first boot the image, the raspberry pi will reboot 3 or more times to complete the initialization process.
firemun
Concord NC
  2. Run balenaEtcher
    Download
  6. Click Flash!
That exactly what I did, downloaded and had the file in my download folder and got the error. Then I tried using the function to flash from the URL and got the error. I was finally able to get the image on the card using the raspberry pi imager but now it asks for a login and the default of "pi" and raspberry will not work. There is not accessing anything past the login screen.
