(/broadcastifySystemId) type must be number
kslager
I keep getting the following error in trunk recorder:
(error) Failed parsing Config: [json.exception.type_error.302] (/broadcastifySystemId) type must be number, but is string
The particular line I think it is referencing is:
"broadcastifySystemId": "xxx",
xxx is the three digit number assigned by broadcastify. I have retyped the number and saved the config, and still get the error. I was running a Broadcastify Raspberry Pi Feed Appliance Image, and built a Ubuntu machine, and simply copied the known working config.json file over.
Any suggestions?
blantonl
Founder and CEO
Dallas, TX
Just remove the quotes and enter your assigned Broadcastify Calls nodeID as the number only.
I fixed this in version 3.01 of the Broadcastify Calls Pi Image
kd4e
Nevils, GA
kslager states that the "broadcastifySystemId": "xxx" is a 3-digit number but I've always used a 4-digit one.
"... type must be boolean, but is string"
I've removed the quotes and re-typed the number - then saved and rebooted - same error.
CrowsSDR
Seasoned Radio N00b
@kd4e
I'm not the authority on this kind of stuff, but it seems as if it's looking for a "TRUE" or "FALSE" value, or perhaps a "0" or a "1", instead of a string of characters.
Boolean is true/false data.
My quotes are for emphasis, it also is likely not expecting a quoted value.
kd4e
Nevils, GA
Then it becomes all the more puzzling.
SID is typically a multi-digit number.
kslager posted his error as "... type must be number, but is string"
My version of trunk-recorder generated "... type must be boolean, but is string".
Perhaps the error I received is itself erroneous?
kd4e
Nevils, GA
Please disregard - I confused lines on the screen.
The error I'm getting is " "talkgroupDisplayFormat": "tag_id", "
There's no mention online of that - so I'll try just deleting the line.
