California Radio Interoperable System (CRIS)
kg6nlw
Railroad & Ham Radio Extrodinare
Sonoma Co., California
RID's 11326 and 11346 both showed up on TG861 (CHP VAL GOLD) in the last 5 hours (0617 and 1032) on 10/29/21...Maybe they are ramping back up for Gold broadcasts again. IIRC, 11346 was the broadcast TG last time around.
Regards,
-Frank C.
mcjones2013
Radio Communications Enthusiast
Sacramento, CA
Regards,
-Frank C.
113xx radios affiliate and disaffiliate on 861 multiple times a day on Site 001 and 007.
Today, I've seen encrypted traffic on 2057 (TDMA) with radio IDs in the 70xxx range monitoring Site 001.
kg6nlw
Interesting...This is about as much activity as I've seen today, besides the CHP VAL-GOLD affiliations...
Regards,
-Frank C.
scannerboy02
If anyone is able to get the key ID on encrypted traffic you hear those can help to narrow down the user. As an example, 0CBD should be a 'State of California' key. While this doesn't narrow it down to an exact user yet, as we are able to get more key ID's those can be compared to other things like TGID's and RID's and it could eventually all start to come together.
scannerboy02
Here is my current talk group list. Information was collected from the postings here.
DecimalHexAlpha TagDescriptionRIDsNotes
11441, 570
11B302
12C
13D
14E7227
2115
221694
2519
261A
271B
281C
915B
10064
12179
1227A
13082113
1318321, 253, 322, 11291
13284102
13385
13587298
13688276, 288, 290, 298
13789
1388A
1398B302
1438F435
14692
14793101, 102, 307
14894101, 102
14995
160A0
251FB1046
30112D"Cap Com CRIS Channel", "Tac Com Copper"7297
4271AB"Tac 1"3001
4281AC"Tac 2"
4381B610, 8194, 8201, 8202, 8210, 8458
7012BD
841349
84234A
86135DCHP Gold Valley ??441, 570, 11044, 11031, 11314, 11317, 11321, 11324, 11325, 11332, 11334, 11339, 11342, 11343
86235E"Blue Channel"203, 11031
1302516208, 51001, 51002, 51005, 51006
1601641
17016A5
17036A7
205780970078, 70105AES KeyID:0CBD
3851F0B
44511163769427, 769428, 769429, 769439, 769483, 769484, 769485, 769487, 769488, 769489, 769568, 769570, 769572, 769575, 769576
44521164769427, 769428, 769429, 769439, 769483, 769484, 769485, 769487, 769488, 769489, 769568, 769570, 769572, 769575, 769576
45011195"Fel Tac"
4502119694404, 94418
50001C351
50002C352
50042C37A
50151C3E770051, 769136, 769143, 769144, 769149, 769155, 769429, 769432, 769483, 769517, 769568, 769572, 769574, 769576
50152C3E8768876
50251C44B70057
kg6nlw
I took a trip to a local hilltop in Cloverdale this evening (around 1700H on 11/15/21). I immediately picked up CRIS Site 50 which had tested Noted in Butte per RRDB. I might suggest it might not be Butte as I do not have a clear LoS, even at 700' ASL of Sutter Buttes. Mt Saint Helena is seen to the RIGHT as the tallest spike of white in FMP24.
The SECOND screenshots shows Mt. Oso coming in at the same level Sutter Buttes should be for me. Meanwhile the RED LINE is where the Site 50 signal is.
Regards,
-Frank C.
mcjones2013
Sacramento, CA
I’ve received Site 50 when visiting Wolf Mountain occasionally.
I also received Site 50 the other night in Wilton using an outdoor antenna tuned for 700/800 MHz. I have pretty-good line of sight to Pine Hill (Site 1, same Control Channel) so receiving Site 50 was a bit of a shock. My portable preferred Site 1. I’m going to chalk it up to placement and weather.
mcjones2013
Sacramento, CA
I’m slightly curious if Site 50 is a portable site-on-wheels for testing, but it would seem weird for such a low site number to be used for portable use.
scannerboy02
I don't believe the notes were indicating that it's possibly Sutter Buttes, from the Wiki information it was heard in Butte County, as well as other areas.
kg6nlw
Yes, but to hear it from 700 feet above Cloverdale, that is something!!
Yeah, I have it as "Site 50, testing noted in Butte Co" which can point to several areas including the Sutter Buttes, and NONE of them receivable by me that far up on this side of the range. So it is strange.
Regards,
-Frank C.
AM909
Radio/computer geek
SoCal
Some orgs like to put their systems together on the ground first, before installing them on the hilltop. Where are the Com Div shops?
AM909
Radio/computer geek
SoCal
I was thinking about the individual radio maintenance shops. Took me a while to find; the state was re-org'd since I had experience with it, but the relevant agency is now OES-PSCD-RCB (Office of Emergency Services-Public Safety Communications Division-Radio Communications Branch), shops listed here.
norcalscan
Interoperating Spurious Emissions
The real northern california
I like the idea of a roaming site for coverage testing etc. but I haven't heard scuttle on that, and I think we're too far into the project for that kind of testing. I believe these things are practically delivered to the sites from Sac as close to turn-key as possible. Chatsworth 19" 48U racks with everything in place or minor assembly if it doesn't fit through the vault door. Area offices and techs tighten things up upon delivery and plug the rack into six 20amp outlets and coax. They are engineered identical at each site, and likely tested at Sac before packaged to ship to the site. No need to unpack and assemble at area offices before getting it to the site.
kg6nlw
RID 16707153 came up on Site 13 today...That's an awful big RID compared to what we have been normally seeing!
Regards,
-Frank C.
Progline
San Fernando Valley, LA County
Is everything on the system Phase 2? I've been listening to the Oat Mtn. Site, which is line of sight to my house, but have not heard any audio on my Phase 1-only GRE PSR-600.
KG7PBS
Sacramento CA
No there is phase 1 and phase 2 Talkgroups on the system. CHP Gold-3 is FDMA also known as phase 1.
