N0WRE
Been looking at getting TK-5210 but wanted to know if its going to pick up the state system? Can someone answer this before I spend the money?
Dakota
Dakota
SkipSanders said:'Pick up'? Can it be programmed to receive the system? Presumably yes, as a VHF P25
Why bother, instead of just using a scanner?
You hopefully know that you aren't allowed to get a personal radio programmed to transmit on the system, no matter what agency you work for, unless you have permission of the agency, and they may have rules about what radios are allowed (if any) that may or may not include this one.
N0WRE said:Been looking at getting TK-5210 but wanted to know if its going to pick up the state system? Can someone answer this before I spend the money?
Dakota
N0WRE said:So without the key scanning is pretty much out of the question? Rats Thanks for the information on that though it helps a lot to have someone familiar with the system to answer the questions I have. I already got a 5210, traded it for some gear that I don’t need and thought it was a good trade, I like it a lot and have been a fan of Kenwood as I own several TK-290, 390 and a 2180 that I use for work.
Thanks again for the information.
N0WRE said:I take it that the system is set up to allow only one talk group per radio? I have heard that thet system was to be 9600 baud and that each department was to have access to each system? Im trying hard to understand how the agencies are supposed to talk to one another if they cant scan to find out whats going on for each agency. But thats just me. So when the new system goes online each agency has to go to a different talkgroup? Seems a bit strange as not the PD can talk to the SO and WHP can to and so on.
You can't be serious? That is so far from the truth. Any radio that would do something like that has buggy firmware. When the XTS5000s were introduced they did that and caused serious CC overload. This is someone who should not be left to make decisions.kd7gxu said:You can have multiple talkgroups, you just can't scan. The thought was that scanning causes too many affiliations and drags down the towers.
wayne_h said:You can't be serious? That is so far from the truth. Any radio that would do something like that has buggy firmware. When the XTS5000s were introduced they did that and caused serious CC overload. This is someone who should not be left to make decisions.
There is still priority scanning for both conventional and trunked. It sounds like the scan lists are not properly programmed.lavy said:There is no priority scan per say like the old days where it checked for the active prioity channel every 2 sec. I've had my motorola radio on scan with only 4 tgid's in scan mode and missed an entire dispatch before it locked on the tgid.
