I am in Rhea County and have just recently gotten into scanners and whatnot. I am on the county fire department and rescue squad.
One of the things I am curious about is what kind of equipment is needed to properly scan the new 800mhz system used in Rhea County. There is a common misconception (mainly because how it was marketed) that the system cannot be scanned or trunked whatsoever and that the system is completely 100% secure. For some reason, I am one of the few that believe otherwise. I am trying to get a handheld scanner to use to show them for one, and two so I can actually see whats going on in the county.
Since they switched off our old system, a good number of us are in the dark aside from the initial tone. (They are still toning on the old frequency and giving the initial dispatch then for most departments everything else is done on the new system.
The new system is a P25 exclusive system. Now I'm sure that means little, unless you're trying to monitor with a scanner. Any scanner will not work. The scanner will have to have to decode the P25 voice transmissions. Now to dumb it down, the scanner can not be analog, because the system communications is digital. You will have to obtain a scanner that can decode the digital voice for the communications to be heard. Now if the type of scanner becomes questionable, this site has a wiki board that provides a listing of all the scanners ever made. What you'll want to do is find all the scanners that can decode the P25 radio transmissions? I'm guessing 7. Then see if the scanner you have matches the make and model. If so, congrats to the new world of digital scanning. If not, be prepare to spend between $350-$550.00. Yes I know, its a large chunk, But these type of scanners are so sophisticated, you'll have to use a computer program to program systems the size of the Tennessee Valley Regional Telecommunications System or TVRTS (optional of course, but much easier). Now if you have any technical questions about the system, Butchgone can really help. I see him as, the "Guru of Southeast Tennessee scanning". His knowledge has made TVRTS system, easier to understand and program. Final note: If for some reason, Rhea County DOES secure the site in your area, no scanner can monitor it. But I do not feel that encryption is the issue versus lack of knowledge about the new system. My suggestion is to find someone in the area, with a digi scanner and test it.
I hope this helps. Good luck and happy scanning.
